Projector light does not shine (power light is on, connections appear good, bulb is new).
I will assume from your description that the projector is powered on and you can look in the rear vents and see the lamp illuminated, yet the light does not shine on the screen.
The Ektapro 9020 and most of the Ektagraphic line of projectors are equipped with a "dark shutter". What that does is keep the screen dark unless a slide drops into the gate. At that time the sensing circuits trigger and open the shutter, allowing light through the slide & onto the screen.
This is a mechanical problem.Look at the metal piece that contacts the slide when slide drops into place.You probably need to slightly bend a part of that piece so it releases the shutter.
Please dont forget to vote this answer was helpful.
Many thanks
