Question about Garden
I need a manual for the Makita G650R Generator please
  • dontbother10
    dontbother10 May 11, 2010
    I think she is Austrialian. I was not able to find any manuals for your your Makita or a Dolmar (real manufacturer) of that size. You can find an 1100 here: Dolmar/Makitahttp://www.makita.ca/index2.php?event=to...http://charlotte.preferredpower.com/DOLM... I recommend you try contacting Makita directly. The link will get you there with a little investigation on your part. If you click on the 1100 model you can download a manual and IPL. If satisfied with my attempt at a solution please reply below and I will close both inquiries. HTH Lou
    President:
  • 2,220 Answers
Answered in clarification.
Posted on Dec 30, 2009
What tipe of oil makita generator g1100 takes
Great generator, i use 15/40 Quaker State it seems to work well for my uses, i have same one, but is 2000. check your manual if your really concerned, the whole thing, is keep oil fuel, and changed often. Hope this helps mike
Jun 13, 2011 | Makita G1100 1100W Generator
What is the recommended spark plug for the Makita G6100R generator
The recommended spark plug is an NGK B6ES plug, you can buy it for just $4.18 with free shipping and not tax from the link I will provide at the bottom of my answer here. This is definitely the best plug for this generator, and is recommended by the manufacturer as well...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
http://www.amazon.com/gp/product/B000CJ3X4O?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B000CJ3X4O
Oct 13, 2010 | Makita G6100R 5800 Watt Generator
Auto idle does not work propertly on makita g 6101 generator
The battery charging is also a load. If the battery is not well charged or old it may need about 60 - 120 W to charge, which is not "Idle".
Jun 24, 2010 | Makita G6100R 5800 Watt Generator
Makita G11oo portable generator. starts on choke. cuts off run
Just noticed your question... If you still need a little help:
1. If the gas is from last year, drain the tank and the carb bowl and replace gas with new. Visually inspect the inside of the tank ..be sure there's no sediment that needs to be cleaned out.
2. remove air cleaner and make sure it's not plugged or dirty
3. plug the spark plug and clean with spray carb cleaner.
4. At end of season, mix some gas stablizer in with the fuel to keep it from going bad while in storage.
Let me know how it goes..
k
May 21, 2009 | Makita 1,100 Watt 2.5 Hp Portable Power...
Makita Generator G2800R
Check your tank for contaminants (water, trash, dirt, monsters, etc), as well as the balance of the fuel system. You may also need to remove the carburetor and clean it out, particularly if the generator has sat for more than a month with fuel in it (most do, including mine) and now has deposits. The only thing that the choke does is make the mixture rich by cutting off the air.
And just for grins, look at the spark arrestor screen on the muffler. This can be related and problematic as well.
Mar 10, 2009 | Makita 2,800 Watt 6 Hp Portable Power...
Garden Logo
223 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
