The Kidsline Cherry Blossom Musical Mobile sure is a mobile, but not a mobile phone.
That is great, because it is not healthy to put a mobile phone so close to our little beloved ones.
just go to settings then select security settings... then select call barring services...select incoming calls only.. take note that when you select incoming calls and barred it you cannot also recieved sms or mms... ok... then activate it and it will ask for barring password.. a 4 digit password.. just put the default password 1234... ok... enjoy...
Phone be in out going or incoming call barring mode, or network problem. cancel the out going and incoming calls barring mode.or flash the phone with Computer.
Somce cell phone carriers can block outgoing texts, separately from incoming texts.. You might want to check with your cell company and see if they accidentally blocked your incoming.
I flashed and flexed the set but to no avail, tried a software update but no update was available from motorola. I then went to the Security settings of the set and restricted all outgoing calls and restricted all incoming calls except the phonebook entries. Then I dialed my mobile using a landline which was on my phonebook and my phone started recieving the calls, then after that I allowed all incoming and outgoing calls. This solved the problem. I believe it is sheer luck because I tried that step earlier on the same day but it gave no result.
ave you set it from inside the profiles for incoming calls. have you turned up the volume from the side of them phone when making or recieveing calls. set your pofile with all the loud tones and then it should work again.
you may have the earpiece volume too low, because you will only recieve a bleep when there is an incoming call, not a ringing tone, or just set it to auto answer in the phone settings.
