Question about Garden
My Makita Generator, Starts but wont run for long. It appears there is a part missing on outlet from Carby? Ned to look at a manual drawing to see what is needed to fix it.
  • Anonymous May 11, 2010
    can you identify what engine is on it? Make? model?
    President:
  • 2,220 Answers
Duplicate post
http://www.fixya.com/PostAnswer.aspx?thid=3649568
Posted on Dec 30, 2009
How do I tune a carby for a Mitsubishi PM 1500 L Scorpion generator
pull the carby and clean it out
the indication is that there is a blockage in the main jet or not enough fuel flow into the carby
check filter in the tank above the fuel tap, check the fuel tap for flow
there is no tune up points as it is a basic carby to run the engine at set rpms
Jul 05, 2016 | Electrical Supplies
Was running fine ran out of gas. put in new gas runs for a while then starts sputtering and cuts off. if you move to partial choke it will keep running. air filter is clean
Hi, the carby has picked up some contaminate from the empty tank. The carby will need to be taken apart and blown out. Hope this helps, regards Phil.
Aug 29, 2011 | Coleman Powermate Powermate 5000W...
I have a G5500R Makita Generator, It has been stored for sometime. I filled it with gas and discovered a leak coming from the left side of the Carb. it appears that there is either a missing screw or...
hi there
pauly46 here
sounds like you will need to remove carby and give a good clean and soak for a while
to remove to green gum / varnish causes blockage of passageways and fuel needle valves to stick and remain open / or closed as well as making it run funny if it runs and flood as you mention
note do not soak any longer than 20 to 30 mins in a carb type cleaner solution as these can attack
non metallic parts and runin them , use compressed air to clean passageways and jets
blow some brake cleaner through them to , if the unit still floods after this , replace the fuel needle valve and seat
here is web site for parts list and parts ordering on line
http://www.ereplacementparts.com/makita-g6100r-generator-parts-c-97_683_688.html
its a god site take look
hope this helps
cheers pauly46
May 11, 2011 | Makita G6100R 5800 Watt Generator
Makita G11oo portable generator. starts on choke. cuts off run
Just noticed your question... If you still need a little help:
1. If the gas is from last year, drain the tank and the carb bowl and replace gas with new. Visually inspect the inside of the tank ..be sure there's no sediment that needs to be cleaned out.
2. remove air cleaner and make sure it's not plugged or dirty
3. plug the spark plug and clean with spray carb cleaner.
4. At end of season, mix some gas stablizer in with the fuel to keep it from going bad while in storage.
Let me know how it goes..
k
May 21, 2009 | Makita 1,100 Watt 2.5 Hp Portable Power...
Honda 30is generator
dear sir i have one honda 30is it not working when i on the key that showing E-03 what is the problem let me now
Feb 20, 2009 | Honda 3000 Watt Portable Generator
Engine missing
Get a DMM that can measure frequency (Hz), then check that with no load and the idle control set to off the frequency is 61.5 Hz - If it isn't you have to troubleshoot why it isn't and correct it.
You should also check the idle control mechanism if there is one on the generator, with it on the generator should start up at regular speed, then slow to idle speed, then rev back up to regular speed when you draw current from the generator. To check it use the DMM to measure the speed at startup ( should be 61.5 Hz), when it idles down (about 37 Hz), when you're drawing power from any other outlet ( pretty close to 60 Hz). If the generator has idled down and you shut off the idle control it should rev back up immediately.
Please rank my solution,
Carl
Oct 03, 2008 | Coleman Powermate Premium Plus 6250W...
Garden Logo
62 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
