Question about Garden
Starts but wont run for long. It appears there is a part missing on outlet from Carby? Ned to look at a manual drawing to see what is needed to fix it.
  • 952 Answers
Thanks for using FixYa.
If your chainsaw starts but wont run for long. You may have a vacuum line problem. The engine isn't able to get a continuous feed of petrol thats why this is happening. Check the vacuum lines...
I hope this helps. Thanks for using FixYa. A fixya rating would be very nice. I'd appreciate that. Thanks and Merry Christmas and a Happy new year =) cheers
- HotRatchet
Posted on Dec 16, 2009
Found that if i spray starting fluid in my carb bike starts for a minute, anyone know where fuse is and fuel pump is, its a 2005 yamaha roadstar silverado.
You should hear a low whirl from the fuel pump when the key is turned to run, do you hear that? The fuse would be under the seat or under one of the side covers. Your owner's manual is the best source of location info of fuse.
Sep 06, 2016 | Yamaha Motorcycles
My 2014 kodiac450 starts missing on acceleration when in differential lock?
check the power draw for the diff lock system as it appears that the current draw is robbing the ECM of enough power to work and run the engine. You may have to have the alternator bench tested for current output. Check condition and tension of drive belt.
Dec 08, 2014 | Cars & Trucks
Tractor starts , but wont run
check float level and operation. check that the idle circuit is clean and if there is a solenoid in the idle circuit ensure that it is working. If the fuel tank is above the carby check for filter / line blockage and that the tap is turning on. as from your description the is insufficient fuel getting to the carby and the bowl is running dry
Jan 26, 2014 | Cars & Trucks
I have put a reconditioned carby on my eh holden it wont start cold with out pourig a small amount of fuel down the throughtof the carby onece running it starts each time perfect sit over night no go
fix the choke to work properly for starters next if you still have the original cast iron manifold then get the butterfly in the exhaust to work as well. It heats up the inlet manifold which helps to vaporise the fuel
Dec 31, 2013 | 1964 Holden EH
Scag wildcat STWC61V-26KA-LC backfiring
check for loose carby or failed carby to manifold / head gasket as it appears that you have a lean mixture problem xcheck for blockage in main jet.
Jun 12, 2013 | Garden
I have a 14.5 hp briggs and srtatton that idles sweet, starts very easily but when you incraes the throttle over 1/3 it runs ok for about 3-4 seconds then starts to miss and puff black smoke. I tried it...
YOU NEED TO PUT A NEW NOZZEL IN IT IF THE OLD ONE IS STUCK THEN YOU HAVE TO DRILL IT OUT AND TAKE A TAP TO IT AND GET IT OUT MAKE SURE YOU CLEAN IT UP GODD AFFTER YOU DO THAT
Sep 30, 2009 | Garden
My mercury 9.8 hp 110 starts but only stays running at half choke
Sounds like it needs a fuel pump kit, and possibly also a carby kit.
take photos as you are pulling the fuel pump or carby apart, or get a service manual for the outboard. The dealer might photocopy the pages you need if you ask nicely.
Jul 09, 2009 | Boating
Garden Logo
19 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
