Toshiba DKT2010H Phone Logo
Posted on Dec 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Banked call? I have what I think is called a "banked call." I push the Msg button and it calls the phone down the hall; I can't get to the message.
Carl Navarro
Level 3:
  • Toshiba Master 2,460 Answers
  • Posted on Dec 16, 2009
Carl Navarro
Toshiba Master
Level 3:
Answers
2460
Questions
Helped
1155833
Points
7314
Message waiting can come from several sources. Usually they are stacked at the phone and you can keep pressing message until they are all displayed. Have the person down the hall pick up the phone when you ring it, or look for the message cancel code and get that message off your set. If it clears, that was the only one and you have no voice mail messages.
Carl
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Feb 25, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
5877
Points
17
For Toshiba DKT2010H phones with no display screen...
First...do not lift handset.
Next press the "INT" button.
Then press the following buttons in this order "#" "4" "0" "9".
(The MSG light should go out.)
Finally press the "SPKR" button.
This works everytime I cannot get the message sender to answer their phone and I want to get rid of that annoying blinking MSG light.
1helpful
My message button is flashing on my Toshiba DKT2020SD phone, telling me i have a message. When i press the Msg button, it it calls another phone extention in another office and i hear that it is on speaker...
This is what I wrote up for our inhouse manual on telephone administration for this phone:
Problem: An employee pushes the Message button to receive a message but it calls someone else's desk. This is caused by whichever extension the phone forwards to when pushing the Message light. For example: if the person at 333 pushes their blinking message light and it forwards to 316 that means that the person at 316 most likely tried to call 333, got a busy signal and accidentally pushed the Message button before hanging up thus setting 333 to call forward to their extension when they got off the phone.
All phones on our system should have this feature turned off, but if it happens this is the two step process to resolve the issue:
Solution: First, push the Message button to figure out which extension it is forwarding to. Take note of the extension and hang up. With the hand set NOT picked up, dial #409 and Release. You may have to do this multiple times to clear the call forwarding because it needs to be done for each incidence that the person accidentally set up call forward. Finally, in the management software go to Station > Station Assignments. Select the extension # that the Message button was forwarding to (the one you noted above). Under the Basic tab at #41 Active Message Waiting select Disable. Select Submit.
Hello, I am having Nokia N-72 and from last two days it is not displaying missed call(eg. 1 missed call) and msg(1 msg received) on screen. plz help in solving this asap.
That show you have missed calls and messages on your phone so you have to click on the messages like wise calls to check the missed calls and messages you have on your phone
Feb 11, 2011 • Cell Phones
2helpful
3answers
I can receive txt msg and make and receive calls on my nokia e65 but cannot send txt msg. Why would this be?
hi....
I think when you send text message it says message failed...right..???
This is because there is option in your mobile called as message service centre number.please check weather this number is correct.Call your service provider and you can get this number.
And also there is an option called as reply via same message centre please put this to 'NO'. now you can send messages
To go to this options please check follow these steps....
1.open 'menu'
2.open 'messages'
3.Go to 'message settings'
4.in that open 'text message'
5.there is an option called as 'message centre',please entre your new message centre number and save it. set this as your message centre
6.Check the option 'reply via same centre' and please put it to 'NO'
Thanx
My call to my sister's pc go to message bank whilst I know she is there waiting for my call
That will happen if your sister doesn't accept your call by pushing the button to accept you call, after a while it will automatically go to message bank, tell your sister to accept the call from you... if she is accepting it and its still not working then maybe its a yahoo connection problem
6helpful
My message button automatically calls another extension How do I get it back to answer my voicemail
the reason the message button is calling another extension is because that extension turned your message light on. to turn off the message light either press the msg button and have the extension answer the call or press intercom #409. You'll have to that for each message recieved til the light goes out.
Ok so my nokia 110i dosnt msg. wen i push the send button it just says message sending failed. my fav fone!! help!!
message centre number is incorrect. restore ur phone to factory settings . call ur customer care nd ask for the message centre number
Aug 03, 2009 • Cell Phones
1 NEW MESSAGE SHOWING ON DISPLAY - folder empty
Hi unfortunately you are going to have to program a softkey to be a MSG key, when you have done this press the MSG key and delete the message- you can then re-program back to the original button. This video shows how to do this, go to http://www.abbeytelecom.com for more helpful videos relating to the Samsung Prostar
Motorola A780
the a780 handset only has the o2 network as default.
to have your phone run with another network sim card, you must call your phone company,ie t-mobile,orange,etc and explain to them you need the browser update msg sent to your handset for picture msgs and also ask for the internet browser update msg too.
when you get the browser msgs sent to your phone, open it and press the left green button, i think? it will give the option to update, you press update.
and all done, happy picture msg. andy. :0)
1helpful
3answers
HOLD BUTTON FLASING, MSG ON LCD SCREEN
Try press ICM button # 3 and the ext number of that phone
1helpful
2answers
Seems to be a key mapping problem
I have a pretty good guess.... someone may have intercomed her phone from another station and then pressed the MSG key. This would leave an intercom message and should light up the message waiting light. Then when you press the MSG button you are returning the intercom call. If nobody ever answers the intercom call the return message will not be completed and it will continue to try and return the call whenever you press the button. SO... if this is the case you just need to have someone answer the other phone that is being called and it should start working the way you are used to again.
Top Toshiba Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
