Hp laserjet 1100 won't feed envelopes normally. what to do?
the roller pick up is delayed and stops mid-way through printing. amber light flashes. ruining many expensive envelopes. yikes.
SOURCE: envelope printing
did you go to the menu in the printer and set it in yhe paper options to envelope? You MUST also set it in the PC. Go to 1- file 2-Print 3-right click on your printer 4-Properties 5-Device settings 6- set tray 1 to envelope
SOURCE: HP Laserjet 1100
Had the same problem with my HP 1100 printer. It was a faulty laser unit. Replaced the laser unit and the printer was fine.
SOURCE: HP LaserJet 1300 Printer - Won't feed paper
firistly try to find out the printer is ready or not then find out when we powearing on the printer then it is warming up or not if it is warning up and not come to ready position then open front cover pull the toner cartage and send back it propely
then give print if the problem is not solved then ckeck the printer cables and drivers
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
SOURCE: HP LaserJet 1012 Printer prints ghost images
A new toner cartridge solved the problem entirely.
