Stop and start over with Router Setup by using a paper clip to press router reset button. Now, with router connected via CAT-5 cable to a computer's NIC. On this computer, using IE or other web access, go to http://192.168.1.1 to access router web setup. Set the Wireless properties, such as SSID (Network Name) and Security properties, like WEP/WPA passwords. This password will be needed by all computers accessing this router's signal. At this point, your router should be putting out a signal identified by the SSID name, all other settings for the router should be set already to the point where it will work, like the IP addresses declared in the router setup. Best left alone, at least till it is up and running. It gets the network address from your Internet Provider, and they are the only ones that can give you an IP address.
Step 2:
Select your Wireless Network Name or SSID then click Connect.
NOTE: If the wireless network name or your SSID is not listed,
the SSID Broadcast on the router might be disabled. For instructions
on how to connect to the wireless network with the SSID broadcast being
disabled, click here.
If the computer is not detecting any signal or is not seeing any
wireless network, change the channel of the router. For instructions,
click here.
If WEP/WPA is enabled on the router:
Step 3:
Enter your wireless network WEP/WPA Key on the field provided then click Connect.
NOTE: To learn more about WEP/WPA and other Wireless Settings, click here.
NOTE: Make sure Display characters is checked, to display the WEP/WPA key used by the router. You can get the passphrase or network key from the encryption that has been generated (if using WEP network security) from the router's web-based setup page. If you're using WPA network security, the network key is the key for passphrase.
Make sure you enter the wireless network's WEP or WPA key not the Passphrase.
It is also possible to make a wireless
connection even if the wireless security is disabled on your router. If
you don't see any network SSID from your network list, make sure your wireless adapter/device is ON and your router is in good condition. If your router shows any unstable occurrence, click here.
Related Article:
Configuring File and Printer Sharing
Unable to connect to a wireless network using WEP in Windows Vista
Windows Vista Articles Listing
Encountering Difficulty Connecting a Wireless Computer/s to the Internet when Connected to a Linksys Router
Setting-Up the Wireless Settings on a Router
Assigning a Static IP Address on a Wired Computer
