New LG RC897T DVD; Cable attached to Tivo; Tivo to TV. The LG does not communicate with the TV or play DVD or Tape. What should be connected to the DVD?
The most likely issue is the output resolution on the RC397T. It could be set to 1080p (progressive) and needs to be 1080i (interlaced). I've seen this happen with other set top boxes. On the front panel of the DVD/VCR recorder, there is a button labeled Res. It's to the left of the USB port and to the right of the DVD/VCR selection button. Each press of the button will change to a different resolution: 1080p, 1080i, 720p, 480p, 480i for HDMI. (The resolution button also changes the component out resolution between 480i and 480p. You may need to step through these choices, as well, even if the component out isn't in use.)
Due to some issues with resetting the resolution, you may need to turn off the DVD recorder and possibly the TV after some of the resolution changes to see any video output change.
I hope this helps. The user manual for the RC897T is available from the support page: https://www.lg.com/us/support/product/lg-RC897T.BUSALLK . The manual link is on the right hand side of the page. My browser gives the direct link to the manual as https://gscs-b2c.lge.com/downloadFile?fileId=KROWM000185603.pdf . See page 60 for the front panel button descriptions.
I had the same problem myself. To fix it,I went into the menu for my Television set and changed the setting to VCR/DVD ... then I used the remote for the LG combo and changed that setting to AVI 1 using the 'input' button under the #9. It would not show on the front of my LG combo but did show on the TV screen. The problem is that your combo and television are not communicating with one another,like speaking 2 different languages.
my solution. tell the people at best buy that the frustration of this recorder caused you to have a nervous breakdown, which caused you to take a mental health day from work, then tell them that they have to re-emberse you for the lost wages, and that you want a free installation of your new device as an appology from the store for selling a useless product designed to make you spend more money. If that doesnt work write a consumer report on the product, send it too every site on consumer reports you can find and continue to repost the report until they finally call you and offer you something free to shut you up. Lmao! Good luck!
it means that your tv has to be on channel 3 or 4 to use device. once your tv is on one of those channels, you should be able to program your dvd/vcr to record and check to see if there is a menu button on your controller. if it is a newer tv, try setting menu on component1, aux 1 or anything but tv..if there is a menu button on controller for dvd/vcr player select that once you see the home screen on tv...
If a cable box is not required for cable signal reception, connect the cable line to the ANT. IN connector on the recorder. If a cable box is required for cable signal reception, connect the cable line to the IN connector of the cable box. Connect a coaxial cable from the OUT connector of the cable box to the ANT. IN connector of the recorder. To view or record a CATV channel:
Tune the TV to the Recorder output channel (CH 3 or 4).
Set the Recorder channel selector to the cable output channel. (Example: CH3).
Select a channel using the cable converter.
With this connection, you cannot record one program while viewing another.If you are using a cable box to tune channels, it is not necessary to do Auto Channel Set.
Click the HOME button on the remote with the unit in 480i resolution
Click the setup page
Click Start
Click TV Aspect
highlight the 16x9 wide aspect ratio
enter on remote control this coded sequence:
1 3 9 7 1 3 9
Edit specific "Options"
Option 2: 35 (enables Divx/Xvid playback)
Option 4: ff (enables Vcd and SVCD playback)
Option 5: ff (enables region free playback (region 0) DVD playback)
Option 6: ce (enables Insignia brand startup logo on boot)
Option 6: c0 (enables LG brand startup logo on boot)
This has been posted on the Internet here and here for an LG RC797T and was discussed here.
Good luck and Thank you for using FixYa. Happy New Year.
Pls be informed that due to my current rank and rating, even a Helpful wouldbe detrimental to my status. Should this solution not address yourconcern, it would be appreciated if you could just not rate this at all. Cheers.
I believe Viore is the same as Samsung. I only noticed this by accident as I bought a Viore TV and my friend bought a Samsung and I noticed both remotes were identical. I tried the Samsung codes and the remote worked. Good luck! Kevin
