Question about Sony Playstation 3 (PS3) Console
Replaced blu-ray laser on ps3 games play but not dvds
Replaced blu-ray laser on ps3 because games/dvds would not play. New one in and games play but not dvds tried restore and still no dvds
Posted by acpagano on
Jesse Allen
    Master:
  • Sony Master
  • 307 Answers
Maybe the DVD laser is damaged somehow. Try ripping the DVD movie and converting it to common video files to play on PS3. PS3 can play movies from USB sticks. Just transfer the converted DVD movies to a USB stick and you can play it directly using the built-in video player of your PS3. Here's how to rip a Blu-ray disc to play on PS3, it also works for DVD: Direct and Indirect Ways to Play Blu Ray on PS3 Respectively
Posted on Jun 04, 2018
rpar
    Master:
  • 414 Answers
There are one laser for dvd, and one laser for bluray, If plays blu ray and not dvds you will need to replace the dvd laser.
Posted on May 04, 2016
Anonymous
    New Friend:
  • 12 Answers
Thats becouse it a BLU-RAY it is diffrent i figured out the hrd way 2 :P
Posted on Dec 15, 2009
2answers
Ps3 slim blue ray won't play can't find settings
Will it play anything? The laser eye may need to be cleaned. Sometimes the drive will play DVDs but not games, or games and bluray movies, but not DVDs .... in that situation, the bluray laser may need to be replaced
My ps3 wont play any of my games, for christmas i got the knew need for speed hot pursuit played it that night and ever since it would not play it nor would it play anyother of my old games, it would only...
Ok your laser is bad. You need to replace it. Your laser has a blu ray diode which lights up blue and reads ps3 games and blu ray games. Then it has a red diode which plays ps2 games dvds cds ps1 games. Your blu ray diode is burned up. You will have to replace the laser its pretty simple.
1helpful
2answers
PS3 will play blu-rays just fine, but not DVD
A bad laser could affect the sound cause it can't read all the information from the disc. Try games as well and see if it does the same thing, sounds like a new drive is in order. There is one laser in those drives and require different strengths to read different discs. Also try a music disc that you know is good. If your still getting the same issue then get the drive replaced or just replace the laser if you have some technical knowledge.
PS3 will play DVDs but not Games. Replaced the hard drive, restored the files, still did not work.
Then the Blu-Ray part of the laser pickup assembly is defect. Since DVD's use a different laser from the pickup, the DVDs will read fine. However the Blu-Ray part is defective and needs to be replaced.
1helpful
2answers
Wont load any disk
Like said above, It needs a new laser. It's a really common problem.
I buy mine at http://parts.consolerepairguy.com they run about $75 each.
I run a repair business and that place has best prices aside from Hong Kong which I don't trust.
2answers
I am unable to play dvds. The system starts with
Try other discs to see if the system is reading anything.
If it isn't then take a can of air and blow some into the drive to make sure there is no dust or dirt on the laser.
After that, try again and if the system isn't reading discs still then that means that the laser is bad. You can either replace the laser or the dvd drive itself.
My PS3 stopped playing blue ray movies, but still plays dvds. Is it a configuration problem?
No, the blu-ray laser is a three part laser. The blu-ray portion has gone out. Only way to fix it is to replace the laser.
DIY 70+
Local Repair 100-120
Sony 150
1-800-345-SONY
1helpful
Ps3 Will Not Play Blu Ray's
Most likely to be the Blu Ray laser. Either broken or not fitted correctly
PS3 Laser DVD/Blu-ray
the blue ray laser has two high energy beams at 450nm(bluelight) and 730nm (redlight). the highpower diode on your machine im afraid has failed. you need to install a new laser ..only 100 i charge or 160 from sony (150+TAX 2 week wait)
Now if you have the newer model laser KES410ACA, then you have 2 SEPARATE light sources...these tend not to fail as often
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
Oloyede Monsuru
Daniel Dollive
Daniel Dollive
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
