Microwave Ovens Logo
Posted on Dec 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My new Whirlpool oven Model number GBD 279 PVS02 error code EO F2
My new Whirlpool oven Model number GBD 279 PVS02 has an error code EO F2 and is now not functioning properly. What can I do?
Anonymous
Level 2:
  • Expert 291 Answers
  • Posted on Dec 15, 2009
Anonymous
Expert
Level 2:
Answers
291
Questions
0
Helped
99658
Points
959
F2 E0 is a shorted keypad. Replace the keypad which is your entire touch pad. In rare cases your ERC or electronic range control can also be bad, unlikely though. Hopefully this is still under warrantee as the part alone is over 150.00. I recommend you have a technician replace this as most parts houses will not warrantee a electical part if a customer installs it. Good Luck, Appliance Specialists.
My whirlpool microwave oven will not power up and shows a code f2. how can i fix it
its an error need to call technical assisstance ..thAT error ranges for faulty temp sensor/probe up to control board ....
Whirlpool mircowave model MH3184XP the display reads F2
There is a problem with the control pad. The membrane, or surface, of the pad may be broken or damaged somewhere, resulting in the F2 error code. This is common for Whirlpool microwaves.
Press "Stop/Cancel" twice and select a new cook program. Press "Start" to begin.
If the error code persists, press "Stop/Cancel" again and unplug the microwave. Wait several minutes and plug it in. If the F2 code appears again, it requires repair.
Replacement membranes can be found online
http://www.appliancepartspros.com/whirlpool-panel-asy-control-8205376-ap3775860.html
but the internals of a microwave are dangerous, having high voltages even when unplugged. With the cost of parts and labour from a service tech, you may be best buying a new oven.
Whirlpool ADG 4956 - problem F2
Hi, here is the answer for f2 "F2 - error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
8helpful
Whirlpool microwave hood combination has code f2 on touch panel. Model number: MH-1150xm
The F2 error means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
On these models, usually the membrane keypad is not available separately, so you would have to order and replace the control panel frame which comes with a new keypad (sometimes called "panl-cntrl").
The part availability and cost will depend on the full model number from the tag on the unit, and it will be one of these:
MH1150XMB0
MH1150XMB1
MH1150XMB2
MH1150XMB3
MH1150XMB4
MH1150XMQ0
MH1150XMQ1
MH1150XMQ2
MH1150XMQ3
MH1150XMQ4
MH1150XMS0
MH1150XMS1
MH1150XMS2
MH1150XMS3
MH1150XMS4
MH1150XMT0
MH1150XMT1
MH1150XMT2
MH1150XMT3
MH1150XMT4
You can order the part and find helpful exploded view diagrams here.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
16helpful
2answers
What does f2 mean?
F2 on a Kitchenaid / Whirlpool / Maytag microwave means you have a shorted membrane keypad.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
On some models, the keypad is available separately.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
On other models, the keypad
is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It all depends on the model number.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
8helpful
Error message on a whirlpool microwave oven ''F2 H2 Hood Keys scanning''
The F2 H2 error code refers to a faulty hood/light switch. This is a combonation board located just behind the buttons on the left panel. The part number for the switch board is 8206049. Since the screws holding this left panel on are only accessable with the door of the microwave removed, I would recommend this repair to be done by a profressional repair person.
1helpful
F2 is appearing on microwave and its not working
F2 on a Whirlpool microwave means you have a shorted membrane keypad.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "F2 fault code".
7helpful
Display has a f2 code on it. whirlpool oven is model mh1150xm and less than 3 years old.
determined from whirlpool that the f2 display is from the control circuit board. the board's problem is intermittent and needs eventually replacing. not covered by warranty. determined that whirlpool has reduced the warranty for the electronic circuits in its appliances from 5 to 1 year. this is great for consumer confidence in whirlpool. have had trouble with 2 other new whirlpool appliances. probably will not buy another whirlpool appliance.
1helpful
Whirlpool Microvave Vent Model GH7208XRQ
It's better to reply back instead of starting a new thread.
Unplugging it for a while and then plugging it back in is how you reset it.
I put in a message to Whirlpool technical to see if they can tell me what this code is. I'll reply back when I find out.
6helpful
2answers
Error code F2.Q1
Not sure what you mean by "Q1 Touch FMEA" above, but F2 error code indicates a bad keypad or sometimes a bad sensor.
Since it's brand new I would first consult the manual. If you don't have it still, you can download it from the owner center here: http://whirlpool.com/custserv/index.jsp
If you still have trouble, since it's new, it should obviously be under warranty, so I'd contact them (same page as shown above) to get it repaired under warranty.
We're happy to help and we appreciate your thoughtful rating of our answer.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
