I was online downloading songs on the ps3 when the ps3 suddenly froze. I turned it off and when I turned it on again, it asked me to send the problem to Sony. Next time i played the ps3 would sign in and out randomly and then it just stopped signing in. When I checked network settings, it said IP address for the router could not be obtained and I could not find any router SSID!! Please help.
Playstation 3 won obtain the IP address Solved Closed
Try that forum. A few solutions that should help you out. If you have a media server on the network that could cause minor issues sometimes too.
SOURCE: PS3 can't obtain IP address through LAN switch
wonderful! that's always a good thing to hear - sometimes it is the "make sure you're power cord is plugged in" problem, eh :)
SOURCE: Ps3 Unable to obtain IP address and connect to internet
maybe the modem set is different from the modem in the lap top in other words maybe you ps3 needs higher and better connection
SOURCE: PS3 will not obtain IP address
Perhaps resetting the router will solve your problem. Have you tried that?
SOURCE: ip address
change its setting from atomatic to mamula and then via using you computer go to RUN type CMD and then there type Ping you will get IP address from here then paste it on Ps3 internet setting..
