It sounds as if your rear roller may have a bad bearing. The bearings themselves are not replacable. The entire roller must be replaced. You can find the parts lited on iconservice.com and enter EPTL09706 in the model number box under the "replacement parts" section of the site. This replacement can be done easily using normal home hand tools.
First remove power to the machine.
Second put the machine into space saver mode. (latched in the up position)
Third go to the rear of the machine and locate the 2 wheels on the rear. There is an allen screw with a nut holding the wheels in place.
Fourth there are 2 screws holding the wheel bracket onto the end caps of the machine.
Fifth there are another 2 srews holding the endcaps onto the frame assembly.
lastly you will be able to locate the two bolts holding the rear roller in place. First mark the bolts where they connect to the actual roller with something so you can see how far to tighten the bolts back onto the new roller. remove the old roller...install the bolts onto the new roller then tighten back down to the marks you made on the bolts.
reverse the process for removing the other brackets.
If after replacing the roller your belt is not straight you may adjust it by this procedure.
If the belt is tracking to the right Then access the right allen screw located on the rear of the machine that connects to the rear roller.
Rotate this bolt CLOCKWISE 1 full revolution. This should move the belt to the left.
Do the same procedure except on the left if the belt is tracking to the left.
Good Luck! Tim
