Question about Opteka (OPT-42XHD2-S1IS) for Canon PowerShot S1 IS 0.42x (OPT42XHD2S1IS) Lens Converter
Canon s1is "lens error, restart camera" appears on screen
Canon s1is lens error
Posted by dbuck857 on
Kiran Anto
  • 420 Answers
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Posted on Sep 11, 2010
LENS ERROR, RESTART CAMERA...
CANON IXUS 561
Lens sometimes does not extend and error message 'lens error restart camera' appears when camera is turned on. This does not work without several tries and much button pressing. Problem is not caused by finger(s) in front of lens barrel.
May 20, 2010 | Canon PowerShot A560 Digital Camera
CAMERA FROZEN..nOTHING WORKS. sAYS "LENS ERROR. rESTART CAMERA"
try to remove the ring over the lens- this is just alluminium ring. I had same problem when my camera felt on floor... i thought its wrecked ... but it was 4 months ago and since that i made thousands of photos and its working fine. Remove the ring, i did it by forcing it, twisting and when removed - lens error was not appearing. I fixed that ring and placed back with a little super glue. Everything is ok.
May 21, 2010 | Canon PowerShot SX20 IS Digital Camera
S1IS black screen .. no image
If you have an S1 IS, this is likely a very different problem (although symptoms may be the same). This is more likely to be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Sep 26, 2009 | Canon PowerShot S1 IS Digital Camera
Lens error: restart camera
If you get that message the lens is stuck.
You should take the camera to a repair center.
They should repair it under warranty.
I have seen this problem a few times already.
Aug 19, 2009 | Canon PowerShot A480 Digital Camera
Canon SC100 Lens Error
I have a 3 year old Canon PowerShot SX100 IS. While testing an external battery power supply I built, the external power connector pulled out while the lens barrel was extending just after I turned on the camera. Power to the camera was lost before the lens barrel fully extended and wouldn't reset when I repowered the camera. The dreaded error message "Lens error, restart camera" appeared and the camera shut down. I restarted the camera over and over and over again but the lens wouldn't reset. I was extremely lucky to find the information here and read various fixes. I didn't want to take the camera apart so I tried various fixes others have successfully used. I first tried smacking the bottom of the camera hard with the palm of my hand just after pushing the on/off button but that didn't work. The one which worked was smacking the camera on the side immediately after I pushed the on/off button. I smacked it quite hard twice with the palm of my hand then, suddenly, the lens barrel began to move and the lens reset itself back to its starting position. Thanks to everyone who has posted here!
Apr 07, 2009 | Canon PowerShot SX100 IS Digital Camera
Lens Error, Restart Camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 02, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon Power Shot S1IS 10x optical zoom 3.2 mega pixels: I turn the camera on and cannot view any subject images either through the viewfinder or LCD screen. The cap is off and the LCD screen and viewfinder...
Your Canon S1IS camera has defect in CCD Sensor and Canon will repair it Free Of Cost. For details, please click Canon CCD Notice and confirm by giving call to Canon.
Regards,
Sep 03, 2008 | Canon Cameras
Canon PowerShot SD630 LENS WONT CLOSE,LENS ERROR RESTART CAMERA
I have the same problem. How do you restart the camera. I have pulled the battery and SD card, but can't get to a menu screen to restart to camera.
Apr 16, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Opteka (OPT-42XHD2-S1IS) for Canon PowerShot S1 IS 0.42x (OPT42XHD2S1IS) Lens Converter Logo
Top Opteka Cameras Experts
ADMIN Canada
ADMIN Canada
Harrie
Are you an Opteka Camera Expert? Answer questions, earn points and help others
