Question about Samsung HLN467W 46" Rear Projection HDTV
Reset tv samsung
Reset tv hln 467w samsung
Posted by pacossam on
Chi Chu
  • Samsung Master
  • 8,457 Answers
Unplug,replug about an hour later should reset it self to factory setting.
Posted on Dec 15, 2009
MY SAMSUNG HLN 507 WX/XAA T.V. IS MAKING A WHINING SOUND WHEN I TURN IT ON
Your color wheel is going bad, when it fails the TV colors will be way off and it will shut down. They range from $50 -$125 . Here is one for $98 for your tv. http://www.amazon.com/Projector-Replacement-Samsung-HLN507WX-HLN567/dp/B00HJOLQ7G
Jan 09, 2015 | Samsung Televison & Video
TV Samsung HLN 61" W don,t turn on at all
A number of Samsung TVs had a bad capacitor. It splits on top. ther are kits on Amazon & EBay for DIY fix or take it to a pro.
May 16, 2014 | Samsung HLN617W 61" Rear Projection HDTV
The fan on the back of our Samsung 5065w HLN television is getting very loud
This is most likely due to the tv being worked in or getting a bit old causing the parts to work harder which produces more heat causing the fan to work harder to keep the tv cool. There really isn't much you can do but by a new tv.
Oct 18, 2012 | Televison & Video
Hln 617w all three led blinking all time ,tv is not on
I am attaching the troubleshooting chart based on that symptom with your model.
May 31, 2011 | Samsung HLN617W 61" Rear Projection HDTV
Samsung hln 467w Ican't turn it on
hi
very common problem with Samsung
you need to replace power suply board
Sep 28, 2010 | Samsung HLN467W 46" Rear Projection HDTV
We have a samsung HLN 5065 w projection tv.
Hi,if you hear clicking it could be the board that powers the lamp its called the ballast Was the fan
running ok? You can clean it w an air pressure
can. If you heard clicking or like wanting to turn on the problem could be with the board that powers the lamp.The board it's called the ballast.If its not able
to provide the power to the lamp it will not turn it on
and the red light will blink.Also pay attention to sounds off buzzing which could indicate a color wheel issue.
Dec 09, 2009 | Samsung HLN5065W 50" Rear Projection...
2004 Samsung DLP HLN-507W1X:Flashing lights
you either need another Lamp which is very possible or Ballast Board. Ballast board is what turns Lamp on, pull back watch to see if there is a Ark coming from spark cap on Ballast board if so Lamp if not Ballast board call Mats for lamp 1-800-628-1118 OR Go to E-Bay for Lamp and Ballast Board Look under TV Parts After rereading your Post I think Lamp! Samsung OEM Had Alot of defective Lamps and do not hold up!
Sep 21, 2009 | Samsung Televison & Video
Samsung hln 61 make loud humming
yes this is a very common issue with Samsung DLp's, and it will get louder and louder until TV will not turn ON anymore. You can replace it yourself is very simple, here is kind of a guide for that http://guides.fixyourdlp.com/samsung/bp96-01579a.php and http://guides.fixyourdlp.com/samsung/bp96-01854a.php
Jun 25, 2009 | Samsung HL-P6163W 61" TV
TV SAMSUNG HLN 567W
call a repair tech for info.
Aug 03, 2008 | Samsung Televison & Video
Samsung HLN 617w1x/xaaa When I turn
blackout this screen,but hear the sound
Mar 18, 2008 | Samsung Televison & Video
Samsung HLN467W 46" Rear Projection HDTV Logo
286 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
