Question about Microsoft Office PowerPoint Home and Student 2007 for PC
Microsoft office has encountered setup contoller error
I am opening microsoft word but i says that the setup controller has encountered a problem during install. review the log files for further information or error... what shall i do?
Posted by myelloyd on
Anonymous
    Champion:
  • 249 Answers
The best thing "try to reinstall ms office" because of "a problem during install", and while installing new one make sure of "customized install" process. Again if you got the same, try to use "specify" the log file "error message", I do wait for your reply.. have fine
Posted on Dec 15, 2009
Error 25090.office setup encountered a problem with the office source engine. system error..-2147024894. please open C..\program files\microsoft office\OFFICE
To fix it, put in your Office 2003 or Office 2007 CD into your drive and wait for the setup program to start. If it doesn't start automatically, find the Setup.exe file on the CD and run it manually. Once the setup window appears, just click Cancel. Click OK to whatever prompts come up after you click Cancel.
That's it! Loading the setup screen fixes the corrupt setup files and allows you to open an Office program without the 25090 error!
See this webpage for explaination
SeeS How to Fix Microsoft Office Error 25090
Jun 07, 2014 | Computers & Internet
Message displays the setup controller has encountered a problem please review log files for further information this happens when i try to open microsoft office 2007
Hi, it sounds like you have encountered a installation problem. Either uninstall directly fron your start menus, or go to control panel, ad or remove programs and uninstall from there. Re boot your computer after uninstall and the re install from disk. If this does not help come back to me, regards
Jul 05, 2010 | Microsoft Office Professional 2007 Full...
I go to install my home and student software and it says an error has incurred while trying to install
Error message when you try to install a 2007 Office program: "Microsoft Office <Product_Name> 2007 encountered an error during setup. Error 1714"
To work around this issue, use the Add or Remove Programs feature in Control Panel to uninstall the earlier version of Office. To do this, follow these steps:
  1. Click Start, click Run, type appwiz.cpl, and then click OK.
  2. In the Currently installed programs list, click the Office program that you want to remove, and then click Remove.
  3. In the Add or Remove Programs dialog box, click Yes.
After the earlier version of the Office program is uninstalled, install the 2007 Office program.
Jan 16, 2010 | Microsoft Office Home and Student 2007...
The microsoft office 2003 installation
First do this
To resolve this behavior, start the Setup program for Office. To do this, follow these steps:
  1. Insert the Microsoft Office 2003 CD in your CD drive or DVD drive.
  2. If the Setup program does not start automatically, locate the Setup.exe file on the CD, and then double-click the file to start Setup.
  3. After the Setup window appears, cancel Setup, and then respond to the prompts to exit Setup.
Note You do not have to complete the Setup program. Setup fixes the error condition when it is first invoked.
If it doesn't help follow these steps.
go to add/remove programs via control panel
the go to office 2003
select "change".
Select repair
You will be asked for the installation CD. Please insert it before start this procedure.
Then do a repair and follow the instructions
Thanks
If this helps you, please rat the answer
Good Luck
Jun 24, 2009 | Microsoft Office Professional 2007 Full...
MS Office 2007 Enterprise installation setup error
Hi, this may not help you because I do not have the exact error you described. But here is some text from the MS website:The installation of the 2007 Microsoft Office suite Service Pack 1 (SP1) fails with error 1935 or with error 78F. This failure occurs when the Windows Installer encounters a reference either to a drive that no longer exists or to a removable media device that contains no readable media. For example, this failure may occur when the Windows Installer encounters a reference to an empty DVD drive or to an empty CD drive. The issue is not caused by the update design of the 2007 Microsoft Office suite Service Pack 1 (SP1). RESOLUTION loadTOCNode(1, 'resolution'); This issue is resolved by update 946691 for the 2007 Office system. Update 946691 is provided to resolve the problem that you may experience when you install the 2007 Microsoft Office suite Service Pack 1. You must install update 946691 on you computer before you install 2007 Microsoft Office suite SP1.
The following file is available for download from the Microsoft Download Center:
download.gifDownload the Office2007-kb946691-fullfile-x86-glb.exe package now. (http://www.microsoft.com/downloads/details.aspx?FamilyId=697BA2AA-0757-42C8-A530-5BD5566A54AD&amp;amp;displaylang=en)
So, here is what they say to do:
Remove the 2007 Office suite loadTOCNode(3, 'workaround');
  1. Exit all programs.
  2. Click Start, and then click Control Panel.
  3. Double-click Add or Remove Programs.
    Note In Windows Vista, click Uninstall a Program or Programs and Features.
  4. In the Programs list, click Microsoft Office Edition 2007, and then click Remove. In this item, Edition is a placeholder for the edition of Office that you installed.
    Note In Windows Vista, click Uninstall.
  5. Click Yes when you receive the following message: Are you sure you want to remove Microsoft Office Edition 2007?
  6. When the removal operation is complete, click Close.
Reinstall the 2007 Office suite loadTOCNode(3, 'workaround');
  1. Insert a 2007 Office installation CD into the drive.
    Note If your version of the 2007 Office suite is a preinstalled version, the installation CD is packaged in the white box that was included with your computer.
    Collapse this imageExpand this imagesecurityshield.jpg If you are prompted for an administrator password or for confirmation in the User Account Control dialog box, click OK, or click Continue.
  2. Enter the product key.
    Note If your version of the 2007 Office suite is a preinstalled version, the product key is located on the back of the CD case.
  3. Read the Microsoft Software License Terms, click to select the I accept the terms of this agreement check box, and then click Next.
  4. Select the type of installation that you want, and then start the installation process.
  5. When the installation process is complete, click Finish.
Jan 21, 2009 | Microsoft Office 2007 Basic for PC
When i open powerpoint 2007 i get a message the setup controller encountered a problem during install.Please review the lg files for futher information.Ihave a vista home premiun and this was alredy loaded...
What I did was I removed Microsoft office and that's when the problem started. I got a setup controller has encountered a problem during install.
If this is the same problem that you got then try after uninstalling going to and moving this folder 'Office Setup Controller' from this location
C:\Program Files\Common Files\Microsoft Shared\OFFICE12 to the desktop.
:D
Dec 08, 2008 | Computers & Internet
Microsoft Office PowerPoint Home and Student 2007 for PC Logo
1,095 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
