Samsung LN52A550 LCD TV Logo
Anonymous Posted on Dec 15, 2009
I have a samsung LN52A550 LCD tv set and it won't show anything with a HD signal. If I hook up a 480I signal the tv will work,but if I hook up the tv antenna or any other hd source to it,the tv goes crazy and makes noise and I see a whole set of vertical color bars like a test pattern generator,then hen the TV will click on and off. If I disconnect the HD source,then the TV will come on and say weak or no signal.
Chi Chu
Level 3:
  • Samsung Master 8,457 Answers
  • Posted on Dec 15, 2009
Chi Chu
Samsung Master
Level 3:
Answers
8457
Questions
0
Helped
2821089
Points
26282
Get a roof or digital antena.Will give u better signal.HD 1080i CBS,NBS check that if u have that in 1080i well able to get HD on the set.U might have a 720p tv set.
I HAVE A 2006 SAMSUNG DLP HL-S7178W {73" PROJECTION TV},IT WILL ONLY WORK ON AIR 3, COMPONENT 1,NOTHING, COMPONENT 2 HAS PICTURE,BUT NO SOUND.I PURCHASE A "CHEAPER" REPLACEMENT BULB INSTEAD OF A SAMSU
If anything were bad with the lamp or ballast, the TV would not have a picture, and would shut off in 30 secs. I think on these component 1 does not run HD inputs--only 480i +480p (progress. scan DVD). Component 2 runs up to 1080i HD but not 480i SD, I think. Your no sound must be something else.
My samsung 550 plasma will not show a screen with I turn the tv on, stays black. I have to cycle power at least 3-4 times before the picture will show up. Once it does, it seems to kick in and out of HD....
Unfortunately although Samsung make great screens they do have a big problem with power supplies. The one in mine went 3 times before I replaced the screen. We have a lot of Samsung's at work and we replace 5-10 power supplies per year. If it's under warranty it'll be done at no cost otherwise you're looking at around $250 (Australian) unfortunately.
Mitsubishi WS-A65 1080 HD Series Won't Switch from 480i to 1080i
Its main digital board has to be replaced. It is a skilled work. If you wish to get more details about this work, check the site linked below and pull up older posts there.
2answers
How do I change video resolution from 480I to 1080p on a toshiba 55sl417u??
The video source dictates what it will show on the screen, 480i video input = 480i display.
If the video source is not 1080p, it will not show 1080p. It works the same as your PC monitor, you adjust the resolution at the PC Video card setting not at the monitor.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
The tv i own: Panasonic TX-32LX77 LCD Monitor (TX32LX77) . i want to know if this is HD. if i hook up the tatasky HD box, will i get a full HD output? thnx
The TX-32LX77 is an HD TV but only has 720p (1366 x 768) resolution. Full HD is 1080p. (SD is 480i.)
I wish that I had better news.
(It's possible that you won't notice the resolution difference; small screens don't always need the full 1080 lines of pixels from top to bottom of the screen to give a crisp picture.)
1helpful
It's staying on 480i sd why not 1080i
There's only one way to get that TV to switch from 480i (which is an SD or Standard Definition signal) - that's to provide it with an ED or HD resolution signal (a 480P signal is often called ED or Enhanced Definition while 720P, 1080i and 1080P signals are called HD or High Definition).
The old standard yellow composite video cable.
You will not get ED or HD signals through the old composite RCA phono jacks (usually yellow in color), either. You'll need to use an RGB (red, green and blue) component video cable, HDMI cable, DVI, or other type supported by both your TV and the video source (CATV box, Blu Ray disc player, Satellite converter, etc.). More on this, later.
RGB cable.
An HDMI cable - this provides Digital audio signals, too.
A DVI cable.
First, you'll need a source capable of sending ED or HD signals. This can be a progressive scan DVD, Blu Ray player, HD Cable or Satellite converter, or a simple TV antenna. Not all DVD players are capable of the 480P progressive scan output - it must be labeled as such. The DVD movies are not labeled progressive scan as they all will play back at 480P if played in a DVD player capable of progressive scan, otherwise they play at 480i. A stand alone Blu Ray player or one in the Sony PlayStation 3, the older HD-DVD in the Xbox360, (it is important to note that the Nintendo Wii can output either 480i or 480P signals only when connected with their special component video cable), "set top boxes provided when you choose HD service from your local cable provider or satellite TV provider are the main sources for signals better than 480i. As mentioned above, the old standard yellow video jack is not capable of supporting signals better than 480i. You must use the HD jacks and cables between to get these signals into your TV.
The Wii 480P cable assembly - includes stereo audio, too.
Lastly, if your TV has an ATSC tuner (it is not uncommon for it to have an NTSC tuner and CATV tuners as well), you can input a UHF antenna directly into the the antenna terminals on the TV. Broadcasters in most areas have been moved into UHF bands - but some areas have one or two that operate in the VHF bands still. Check antenna web for information and help selecting antennas and broadcasters in your area. The nice thing about the antenna method is that no other cables, converter boxes, etc are needed to enjoy HD signals - plus - they're free!
Just remember you need a source capable of ED or HD signals and a way to get those signals to your TV. The yellow composite cable is from days ago and only passes 480i signals.
I hope this helps and good luck! Please take a moment to rate my reply - thanks!
Watching ln52a550 and picture went blank. Hooked 32" samsung up and everything works fine. Anything I should do before contacting warranty service?
This model has had problems with electrolytic capacitors on the power supply which will cause your problem. I've fixed several of them by replacing these caps. The caps will most likely be bulged or mushroomed on top if they are bad. This is the most common problem that I have found on this model.
If it is in warranty, then I would just contact Samsung and they will send a tech out and he will fix it for you at no cost.
I am trying to hook the Philips 30pf9946 up to an HD Tivo
I am wondering what you are making the connection with, If you are using s-video or composite from your tivo to your hd tv it will only produce 480i. in order to get 480p and above you will need a component video cables or better(hdmi) in order to produce the signal. You may have already known this, but I couldnt tell be the information provided. Hope this helps.
8helpful
Want to change my sharp hd tv from 480i to 1080p
You Can Not Change. The TV Recognize the signal on the INPUT.
If the signal is 480i than the tv shows 480i
If the signal is 1080p than the tv shows 1080p (if supported)
If you try with your areal antenna (for now digital broadcast is maximum 1080i (in USA) The TV itself doesnt "upconvert" lower resolution signals.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
