Question about Canon Cameras
I need to restart my camara.
When I press on the camara swich off and tell it tell me lens error, restart camara.
I don't know how to do it. can some one help me?
canon digital ixus 70
Posted by mcmr31 on
Anonymous
    New Friend:
I just got a fuji digital camera. I was taking pictures and it said memory full and then the lcd screen went dark gray with a green dot in the middle. I then opened the memory card and installed it. I can still take pictures and see thru the focus lens but not the lcd screen.????? pls. help
Posted on Dec 15, 2009
My brench of camara name Powershot SD1300is digital. when i turn on with my canon camara i see lens error will shut down outomatic restart camara.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 23, 2011 | Canon PowerShot A560 Digital Camera
Camara lens won't go back in
lena unit is bad,diassemble the lens unit,replace the broken/deformed parts,service all the parts,assemble to operate the camera.
Apr 09, 2010 | Canon PowerShot A530 Digital Camera
I dropped my camara and now it says lens error, restart camara
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 10, 2009 | Canon PowerShot A550 Digital Camera
Cannon sd880
Jan 13, 2009 | Canon PowerShot SD880 IS / Digital IXUS...
Lens error. restart camara
  • taking the battery out for a couple of minutes and trying to open the lens again, or
  • banging the living hell out of the thing on a hard surface to see if that will knock some sense into it.
  • those listed above are the two most common fixes for lens errors like that.
    sounds odd but alot of people have had their cameras fixed from the bottom of the two I personally have not tried it but think if something just needs to be re adjusted im sure it would help
    did you by any chance here any grinding on it when it was going in and out?
    Canon would suggest the following "send in for repair or buy a new one" so hopefully one of those above helps.
    let me know
    Thanks
    Aug 16, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
    Lens error, restart camara issue in SD900
    Hey GeorgiaPlum,
    What is most likely happening is there is damage to the lens or the lens mechanism and you should have the camera looked at by an authorized service technician. I will say that digital camera repairs often exceed the value of the camera, but it can't hurt to get an estimate done. I hope this helps!
    Sincerely,
    Allan
    Go Ahead. Use Us.
    Jul 05, 2008 | Kodak EasyShare C613 Digital Camera
    Lens Error
    It is just telling you to try to turn the camera off and back on. This usually doesn't self correct and will need to be serviced. I would call Canon for support and see what the options are for service or upgrade.
    Hope this helps!
    May 13, 2008 | Canon PowerShot A460 Digital Camera
    well **** that doesnt sound complicated or anything.
    Feb 29, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
    Cameras Logo
    144 people viewed this question
    Top Canon Cameras Experts
    old marine
    old marine
    Ekse
    Poul Brinchs Larsen
    Are you a Canon Camera Expert? Answer questions, earn points and help others
