Question about Vector 1 Million Rechargeable Spotlight
Where can i find a replacement battery for my VEC 117
Paul Havemann
    New Friend:
  • 15 Answers
Vector was acquired by Black & Decker in 2006, and their old website just sends you to the B&D site. I have had no luck finding a replacement battery.
However, Amazon.com still carries the original Vector 1-mil spotlight.
Posted on Jan 09, 2010
  • Paul Havemann Jan 09, 2010
    Found it -- DeWalt carries the VEC195 battery:
    http://www.dewaltservicenet.com/Products...
Anonymous
  • 3 Answers
Probably cheaper just to buy a new light
Posted on Dec 28, 2009
1 Related Answer
Boneebone
  • 973 Answers
SOURCE: Need replacement battery for spotlight
You can purchase a battery from Black and Decker, they purchased Vectorlite in 2006, here is the link, you will need to enter the model #
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Posted on Jun 17, 2010
Do I find a 12 volt recharger for the VEC 137CO
Radio Shack sells AC/DC replacement chargers that will work with the VEC 137CO. Or Sears do exactly what you need, see Link
Dec 16, 2014 | Camping, Backpacking & Hiking
Where can I order a replacement charger for vector trailtracker sport lantern/weather radio model VEC 1198POB
If charger can be taken apart and the battery removed, try Batteryspec.com for a replacement battery. Worked for my Vector.
Aug 15, 2013 | Black & Decker 50 Watt Electromate with...
Vec 1097 A battery charger always give cod F03 with any battery
The battery in question so bad it wouldn't even register on the charger unit to any degree. I know this makes no sense, and kinda negates the whole point of even having a battery charger to begin with, but I learned of the battery it's attached to is too bad it won't even allow you to do ANYTHING with it.
Dec 06, 2012 | JUMP START SYSTEM
No work is done by gravity on a bowling ball that is rolled along a bowling alley because why?
If the bowling alley is perfectly horizontal, the center of gravity of the ball will remain at the same height measured in a fixed system of reference. As you know the gravity force is directed vertically downward. To calculate the elementary work of that force you evaluate the inner product dW= vec(g).differential of vec(5). However since the displacement vector vec(r) remains in a horizontal plane ( Prependicular to the direction of vec(g), and the ball does not bounce and leave the horizontal plane) the angle between vec(g) and vec(r) is equal to 90 degrees. the inner (scalar product is =0).
A simpler way to remember it is that the work is equal to g*(difference in height)
Jan 07, 2012 | iPhone Apps
My digital screen reads:service 4wd switch
  • The 4 wheel drive switch tells the VEC- Vehicle Information Center - weather you are in 4 high or 4 low.
  • It's on top of the transfer case between drivers side from and rear doors.
  • The VEC has been know to cause this problem to so if the switch does not fix it then the VEC might have a loose wire or be malfunctioning. The VEC plagued the Grand Cherokees for a few years.
  • This is a dealer part.
  • Also check the transfer case fluid level while there. Pull the top plug and fill it until the fluid just barely seeps out.
Regards, Tony
May 25, 2011 | 1996 Jeep Grand Cherokee
I have not been able to find a store who handles the vec 142 in our area I have questions like battery battery life and how much are replacement batteries if available what is life of bulbs and how are...
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service.
Nov 01, 2010 | Vector VEC 142 Rechargeable High Intensity...
Jun 10, 2010 | Vector 1 Million Rechargeable Spotlight
A ups mosfet ckt one mosfet burnt out og 16 can i replace only one
Usually the mating one has been degraded or damaged as well. Replace as a pair, or all of them that are in the same function.
OFTEN driver transistors and drive diodes are also damaged. Carefully check all associated components to avoid burning out freshly replaced ones.
Mar 14, 2010 | Vector VEC 024 400-Watt Power Inverter...
I need to find replacement ground (thumb screw) for vector 024
ground it off on the case...any grounding method should work. Unless you are talking about the main connection terminals... then just replace the missing thumb screw with a short screw and an eyelette type connecter.
Nov 18, 2008 | Vector VEC 024 400-Watt Power Inverter...
Vector 1 Million Rechargeable Spotlight Logo
1,026 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
