Question about HTC Qtek 9100 Smartphone
Change language to english.... my phone`s current language is german....how can i change the language to english? this phone came from my sister who is in germany right now!....
Posted by quickxilv3r2 on
MUSTAFA BULENT KILIMCI
    New Friend:
  • 166 Answers
Yes you can change it via editted rom file with hex editor change it GER to ENG
Posted on Dec 15, 2009
How to change language at nokia 6290 from german to english
Go to menu -> settings -> phone -> language settings -> phone language -> choose English =)
(in German it would say) Men? -> Einstellungen -> Telefon -> Sprache Einstellungen -> Telefon lenguage -> Englisch
Apr 09, 2016 | Nokia GPS
GERMAN TO ENGLISH ON MFC
Hello, you can try this simple steps configure your language in any language you want; english, german or japanese or even more! And this is the steps, kindly follow it thoroughly to changed it with ease;
1. Open your phone.
2. Tap Menu.
3. Tap Configure or Settings. (a wrench icon)
4. Tap Phone. (a phone icon)
5. Tap Language Settings.
6. Tap Phone Language.
7. Tap the language you want.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Brother Printer Support
Feb 04, 2014 | Brother MFC-990CW COLOR INK-JET MFC Ink...
My htc legend is in german. I need help to make the language from german to english and i will need german instructions because everything is in german thank you kind regards akila
Hi Akila,
In normal case to change the language of the operating system press HOME > MENU, then tap Settings > Locale & text > Select Locale and then select the language you want to use.
And
If you have installed 'rom' by selecting a language after purchase then the only way to change it is to install a new rom with the language you want. The issue is that Windows Mobile does not allow the user to change the language of the rom once it is installed.
You need to contact HTC to ask them for a replacement rom that is in English.
Hope this helps, Please leave a comment and rate if the solution was helpful, thanks!
Aug 02, 2011 | HTC Legend Cell Phone
My htc tytn is in german i wish to change the language to english. should i flash the phone or just reinstall a new software
Go to phone settings and change to English,get a German to help with the GERMAN LANGUAGE
Jul 04, 2011 | Cell Phones
How do you change the language to english on the lg gt450
(Found on eHow.com)
1) Click Menu
2) Move through the menu until you find something which resembles "Settings & Tools" (If you know what language your phone is currently in, you can use an online translator to help.)
-Spanish "configuraci?n"
-German "
Einstellungen"
3)Click something which resembles "Phone Settings"
-Spanish "Programaci?n del tel?fono"
-German "Telefon-Einstellungen"
4)Click something which resembles "Language"
-Spanish "Idioma"
-German "Sprache"
5)Choose English, and hit ok.
Best of luck!
-12
Mar 01, 2011 | LG GT540 Cell Phone
We cant change the language from German to English,, How we can change it?
Thanks for visiting FixYa!
The first thing you are going to need to do is to take a look at the manual for the phone in English (if you can't read German.)
Then, you'll need to view an owner's manual in German - to compare the directions. And, third, you'll probably need an online translator to translate German to English.
The link to view the manual in English: http://www.motorola.com/staticfiles/Support/IN-EN/Mobile%20Phones/C118/IN-EN/_Documents/Static%20Files/C118_UG_IN_EN_6802923J10_V1.pdf
The link to view the manual in German: http://safemanuals.com/user-guide-instructions-owner-manual/MOTOROLA/C118-_D (Look to the top right of the page in the top of the box - Manual is in German.)
Here's a link for an online translator: http://www.worldlingo.com/products_services/worldlingo_translator.html
The option for language (change) should be in settings.
Feb 10, 2011 | Motorola Mobility C118 Cellular Phone
HOW TO CHANGE LANGUAGE FROM GERMAN TO ENGLISH ON NIKON COOL PIX 4000
Press the Menu button. Select Setup (the wrench icon, or else the last item). Select Language (either the waving flag icon, or else "xxx/Language" where xxx is Language in whatever language is currently selected. No matter the language, it should still say "Language" in English after the slash. In that menu, each language is labeled in that language, so you should see "English" as one of the options. Select that, and everything should be back in English.
Dec 25, 2010 | Nikon Coolpix S4000 Digital Camera
How do I change the language from German to English
Well you may please follow the steps below to change the language to English on TI-84 Plus -
• Press the [APPS] key.
• Under the applications listed select the language currently on the calculator (For example Francais, Espanol, Dutch...) and press [ENTER].
• On the Language Localization screen, the choice to select a language is given. Select English and press [ENTER].
Good Luck!!
Thanks for using FixYa!!
Aug 20, 2010 | Texas Instruments TI-84 Plus Silver...
Changing the language on the screens it is presently in German want to change it to English
yup, u can change language, but must using flash box, Flash PPM file to change language, any language, if you have no flash box, send to your technician to do that, only a few minute only if your technician not bz..
Apr 12, 2009 | Nokia 1600 Cellular Phone
Phones
obviously if you know the german word for "language"it would help greatly.you need to press the button that is labelled program then press the scrollbar (below the keypad) and each time you press the scroll the display will show a different menu.when you see something like afspraak (german word for language ?) select the digit beside it and you are then in the language menu.then select english for your language choice.i hope this helps
Aug 06, 2008 | Nortel Meridian M3820 Corded Phone
HTC Qtek 9100 Smartphone Logo
469 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Rob Woolcock
Rob Woolcock
Marvin
Marvin
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
