Maytag DG 313 Gas Dryer tumbles but no heat. The igniter does not ignite.
First Check your lint trap. Clean it as necessary.
Check the admission valve make sure it is opened .
Testimonial: "valve was open, we cleaned the lint...there was quite some lint, but line was not clogged. thanks for the tip. merry christmas and God bless you"
I believe this unit has a hot-surface ignitor, and they work great, but do go bad eventually. The easy way to tell is to visibly see if the ignitor is operating during startup... can you get to it?
The hot-surface ignitor is easy to replace- (be careful not to touch it with fingers - like with halogen bulbs)
Testimonial: "yes, this exactly is the problem. the ignitor looked burned in one spot. i bought a new one today, $ 30. thaks for the tip. Merry Christmas God bles"
Hi
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
