Calibrating the temperature resolves the THS error in most cases.
The ‘Temp Cal’ functions can be carried out in the following way;
·Start with the printer powered OFF and at normal room temperature ·Hold down the ONLINE and SETUP button and power the printer back on ·Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line ·Press the button under ‘TEMP CAL’ (button 3) ·Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating. ·Then press SET to save the settings.
If the printer continues to display the THS error, the problem can be caused by;
Incorrectly seated print head
Damaged or incorrectly seated head cable
Fault with Main Board, Interconnect Board or the print head.
