Question about Canon PowerShot SX100 IS Digital Camera
I CAN'T GET THE DATE TO TURN ON. IT WILL LET ME RESET IT, BUT IT WON'T LET ME TURN IT ON. When I go into the menu setting, it shows that the date is turned off and I can not access another menu that will allow me to turn it on. I need to date stamp pictures for work. Thanks for your help.
Posted by tufenufbull on
CameraR
  • Canon Master
  • 4,738 Answers
The date/time stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution.
Then press the menu button. Select the "Camera" menu, then scroll down to the the Date Time Stamp selection to turn it on.
Posted on Dec 15, 2009
5 Related Answers
old marine
old marine
  • 2313 Answers
SOURCE: Date stamp
In order to use the date stamp option, the image size (L, M1, M2, M3, S, Postcard) has to be set to Postcard. Press the Func/Set button, scroll down to the image size icon (lower left corner), then scroll over to Postcard, and press the Func/Set button again.
Posted on Jun 10, 2008
arclight1217
BRIAN REISS
  • 208 Answers
SOURCE: Setting date and time on the picture
OK, I FOUND SOME INFO ON A WEBSITE THAT I'M GOING TO HOTLINK FOR YOU. SEEMS LIKE THE ONLY WAY YOU CAN DATE/TIME STAMP A PHOTO IS TO HAVE THE CAMERA IN THE POSTCARD MODE. YOU CAN READ ABOUT THIS IN THE WEBSITE I'VE LINKED FOR YOU. HOPE THIS SOLVES YOUR QUESTION, AND IF YOU NEED MORE HELP, REPLY TO:ARCLIGHT1217. IF THIS HELPS, PLEASE REMEMBER TO RATE THIS SOLUTION. THANKS!
http://www.imaging-resource.com/PRODS/SD750/SD750A3.HTM
GOOD LUCK!
Posted on Nov 13, 2008
Anonymous
SOURCE: Date/Time Stamp option is greyed-out
An online review says the date stamp only works in the "postcard" image format. http://www.dcresource.com/reviews/canon/powershot_sd850-review/
Al
Posted on Aug 31, 2008
Anonymous
SOURCE: date stamp will not show on my camera
I found the solution o-line. All I had to do was switch the camera to the 'postcard' mode and instant presto, I was able to access the date stamp mode. I want to express my thanks to the (I don't remember who) person who posted the solution.
Posted on Jul 01, 2009
Anonymous
SOURCE: i have a canon powershot
When you turn your camera on, there is a screen which appears in the viewfinder. Push the FUNC SET button and then scroll down the column on the left of your viewfinder until you come to the one with the letters M1 M2 M3 S, etc to the right. Then select the one called "Postcard 1600x1200" by scrolling to the right. Your camera is then in the post card mode. You can then go to the date stamp in the menu and your camera will not skip over it any longer! EUREKA!!
Posted on Sep 20, 2009
Panasonic dmc-FH27 date stamp
Touch MENU to bring up the menu. Select [REC], select [Date Stamp], then select [Off].
See page 83 of the Advanced manual: http://service.us.panasonic.com/OPERMANPDF/DMCFH27_ADV.PDF
Sep 07, 2013 | Cameras
Reset
To reset the camera, remove the battery for 15mins. replace the battery to open the camera's Menu then scroll to Date & Time setting, and set the current date and time.
May 04, 2013 | Canon EOS Rebel XSi Digital Camera
Time and date won't save
Replace the date/time battery. See the instructions on page 87 of the advance user guide.
Jun 11, 2012 | Canon PowerShot A410 Digital Camera
Can I turn the date stamp on for a nikon coolpix 2000 camera. It tells me I have an internal date but the date is not showing up on my pictures.
Firts set the time and date
Go to "Setup" menu
Highlight "Date"
Display DATE menu
change yera. miont, day , hour
left menu
Time and date of recording is included with all pictures
taken with your Nikon digital camera.
try again , take a picture and look if show date time
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Nikon Coolpix 2000 Digital Camera
How do I change the time on the Brother 2820 fax?
This was taken directly from the Brother 2820 Manual:
Setting the Time
When the machine is not in use it will display the date and time. If you set up the Station ID the date and time displayed by your machine will be printed on every fax you send. If there is a power failure, you may have to reset the date and time. No other settings will be affected.
1 Press Menu/Set, 0, 2.
[2. Date/Time]
2 Enter the last two digits of the year.
Press Menu/Set.
3 Enter two digits for the month.
Press Menu/Set.
(For example, enter 09 for September,
or 10 for October.)
4 Enter two digits for the day.
Press Menu/Set.
(For example, enter 06 for 6th.)
5 Enter the time in 24-Hour format.
Press Menu/Set.
(For example, enter 15:25 for 3:25 P.M.)
6 Press Stop/Exit.
The LCD now shows the date and time
whenever the machine is idle in Fax
mode.
When the machine is in Sleep mode, the
LCD shows Sleep. (See Sleep Time on
page 2-8.)
Turning on Automatic Daylight Savings Time
You can set the machine to change automatically for Daylight Savings Time. It will reset itself forward one hour in the Spring and backward one hour in the Fall. Make sure you have set the correct date and time in the Date/Time setting.
1 Press Menu/Set, 1, 5.
[5. Auto Daylight]
2 Press Up Arrow or Down Arrow to select On (or Off).
Press Menu/Set.
3 Press Stop/Exit.
May 03, 2011 | Brother IntelliFax-2820 Laser Fax
Hello we have a Brother 2820 Fax Machine and we cannot find the Instruction Manual and we need to reset the time can you please advise us on how to do it. Thanks Marie
1Press Menu/Set, 0, 2.
2 Enter the last two digits of the year. Press Menu/Set.
3 Enter two digits for the month. Press Menu/Set.
(For example, enter 09 for September, or 10 for October.)
4 Enter two digits for the day. Press Menu/Set.
5 Enter the time in 24-Hour format. Press Menu/Set.
6 Press Stop/Exit.
The LCD now shows the date and time whenever the machine is idle in Fax mode.
When the machine is in Sleep mode, the LCD shows Sleep. (See Sleep Time on page 2-8.)
Hopefully that worked correctly and solved your problem!
Apr 07, 2011 | Brother Office Equipment & Supplies
How do I set date and time
1. Press MENU to enter SET UP menu.
2. Press right or left arrow to reach the settings.
3. Then go on to view the menu
4. Find Reset Camera Settings.
5. Reset your camera.
6. Turn on the camera
7. Date/Time settings will appear.
8. Set your date/time.
Jun 03, 2010 | Kodak EasyShare V550 Digital Camera
How to set date on m863
Press the menu button and go into the setup menu. Find the time and date setting and set it. You might also have to reset the time and date stamp, if you want it to show on your pictures.
Dec 31, 2009 | Kodak EasyShare M863 Digital Camera
Ge model 27909 answering machine gives wrong time on playback
I found it on the manual, it was in programming section!
Date/Time
NOTE: Time set on handset will be transferred to the base unit automatically.
1. Make sure your phone is OFF (not in talk mode).
2. Press the menu button to go to the main menu and use cid/vol (3or4) button to scroll to Date/Time.
3. Press menu button to enter the menu. Year 2006 shows in the display.
4. Use the touch-tone pad to enter the last two digits of the current year (range: 00 to 99).
5. Press menu button to save the year setting and proceed to date setting.
6. Date 01/01 shows in the display. Use the touch-tone pad to enter two digits for current month and day respectively.
7. Press menu button to save the month/date setting and proceed to time setting.
8. Time 12:01p shows in the display. Use the touch-tone pad to enter four digits for current time and use cid/vol (3or4) button to toggle between "p" (pm) and "a" (am).
9. Press menu button to save the setting. Saved shows in the display.
NOTE: If you subscribe to Caller ID service, the current date/time is set automatically when you receive your first CID record and will override manually set date/time.
Jan 08, 2009 | GE Lands Phones
Canon PowerShot SX100 IS Digital Camera Logo
850 people viewed this question
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
