Paradyne 6211 ADSL2+ Router (6211I1200) Logo
Posted on Dec 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unable to use admin username remotely - Paradyne 6211 ADSL2+ Router (6211I1200)
Anonymous
Level 2:
  • Expert 481 Answers
  • Posted on Dec 14, 2009
Anonymous
Expert
Level 2:
Answers
481
Questions
Helped
175707
Points
801
Most routers do not allow admin access from their WAN (public) side due to security concerns. Many routers allow you to enable this service from their browser-based configuration screens, but the 6211 does not. However, you can access advanced commands by logging into the router with telnet (from the LAN side) instead of a browser. The "remoteaccess" command allows you to turn on the feature you desire.
Full instructions for the command-line interface are here:6211-I1 ADSL2+ Router Command Line Interface User's Guide
You may need to upgrade your firmware to 3.00.22: Zhone/Paradyne Firmware - TSTT Forum
I was unable to login as admin in my dir600 dlink router...but i can login as user...how can i login as admin?
The default admin username is "admin" with no password.
The default adress is http://192.168.0.1
If you are still unable to connect, the password may have been changed. Reset the router with the button on the back, and try again.
tip
Default IP, Password
The factory default settings for the WAP54G are:
  • IP address: 192.168.1.245 (Note: NOT .254)
  • password: admin
  • username: blank -- there is no username by default.
Some versions of Firefox and Safari will not let you authenticate with no username. If you're unable to log in with a blank username, try admin
2helpful
2answers
Hi guys, i just got a thomson twg870 and i'm trying to connect to 192.168.0.1 but i can't find the username and password. I tryed with admin and "password" but it's not working. Any ideas? Thanks
pankystu,
The default username and password for most routers is:
username- admin
password- admin
OR
username- administrator
password-
Hope this helps.
-S
1helpful
Can't configure the database connection for Primavera p6
i just installed Primavera Project Management , and Methodology management. After logging in with the default username of admin and password of admin it comes back with the message " Unable to connect to the database. Would you like to configure the database connection now?" How do I get around this challenge? iam using vista
2answers
Need default password to reset Gateway WGR-200 router
Default username and password is "admin" for both. You can get the user manual here.
Can't get it configured
Try to reset the router using a paper clip, then try to re-log in to the router with the IP address, If you are still unable to log in , try log as admin as the username and password as admin or admin on the username and password is password.
4helpful
3answers
How can I reset an unknown admin pw on Linksys RV042 VPN Router? I'm the new IT guy here, and I don't have the admin pw for our VPN router (and I need to provide remote access to a colleage working...
you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and reconfigure it again.
To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router Password: Admin
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigure the LinkSys router
Having trouble accessing router with ipod touch and nintindo dsi
In order to Unlock Netgear router you need to know the login password for router's login page and if that does not work, you can try with a default username : admin, Password : admin, still if you are unable to access the routers page then you need to reset the router by inserting a pin in the pinhole where it says reset at the back of the router...press and hold down the pin for 30 seconds and then restart the router, this will take the router back to default settings and then apply username : admin and password : admin....it should work
Netgear address : 192.168.0.1 ( Type in IE address bar to access it )
Regards,
Anup
3answers
How to reconfigure router
you may need to reset to restore the defaults.
the the default username: admin and password: admin
Top Paradyne Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
