When i try to move the analog stick, the psp does not react. what should i do?
Check to make sure the headphone/tv output jack is not pushed in farther than its supposed to be. youl know if its in to far. if its fine then you mite need to replace the joystick chip. its not that complicated of a procedure.
first off buy another joystick make sure its for your psp first there are different modles.
oper up your psp. to do this (depending on your modle) unscrew the little screw that are on the outside plastics. there is 2 under the batter one of tem you can see the other is under neith the sticker at the bottom poke around to find it
once you have your psp open your scree will get in the way so dont unplug it but just bring it out of the plastic brace that has it in there. there will be lil aluminun strips on the side that hold the screen still just pop those out of there holes careful not to crack the screen.
then your motherboard mite get in the way so you will need to just lift that one up and out of the way be carefult not to break any plugs. once you have that up your joystick should be acessable. if there is one more just unscrew that one andset it aside for now.
just insert your new joystick in place of the old one and go back threw that steps till its together again
i cant be held responsible if something goes wrong OPEN YOU PSP AT YOUR OWN RISK
good luck its isnt hard really
