IC8C01 STK393-110 how do I replace this part? Need to know where I can find diagram
IF it uses the STK-393-110 it is not a WD52525.
What is exact model number on back of set?
Mitsubishi sets using the part are rear projection sets--
I have START TO FINISH, STEP BY STEP INSTRUCTIONS FOR REPLACING THE STK-393-110 CHIP IN SETS THAT USE IT--available here for free if you need them.
They tell you everything you will need and how to do the repair--a site on EBAY sells the chip for about 11 dollars plus shipping.
The reason I composed the instructions is I have repaired hundreds of these sets and you are not the first person who has asked this question here--
If you want the instructions let me know and I will post them here for free.
If this helps you rate this solution as I do this here for free. Keep in mind--the instructions I wrote from my own experience doing this repair many times.
If this information helped you, rate this solution as I do this here for free.
SD TECH
Can you please send me the instructions to replace the STK-393-110 on a WS-55511 Mitsubishi set?
[email protected]
Hi. Was your issue related to no power uo (Blinking green light then nothing?) Did you get it fixed? If so, Do you still have the instructions?
Hi. Was your issue related to no power uo (Blinking green light then nothing?) If so, Do you still have the instructions?
[email protected]
Can you please send me the instructions to replace the STK-393-110 on a WS-65712 Mitsubishi set? e-mail [email protected]
