Question about NorStar T7316E Telephone
How do I change the time on my T7316E phones?
Posted by info68504 on
Carl Navarro
  • NorStar Master
  • 2,460 Answers
Look at your Administrator manual for the FEATURE **TIME command.
Carl
Posted on Dec 14, 2009
  • Startemp007 Mar 23, 2011
    If I could access the Administrator manual I wouldn't be seeking an answer on-line. I am in a temp position and all I've been given for the phone system is a quick reference guide that doesn't give much info at all.
5 Related Answers
Anonymous
SOURCE: changing name in nortel T7316E handset
instructions are toward the bottom of this page:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
Posted on Aug 26, 2008
Anonymous
SOURCE: How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password Retry Step 2
Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options:
Hour: 01 Next Change Step 3
Select CHANGE - the display will show the following options:
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00 Next Change Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99 Next Change Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Posted on Mar 12, 2009
consultel1
george peters
  • 860 Answers
SOURCE: How do you get a t7316e phone to ring
Programming2_bing.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Posted on Dec 12, 2009
consultel1
george peters
  • 860 Answers
SOURCE: NEED TO CHANGE TIME ON PHONE DUE TO DAYLIGHT
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Posted on Mar 16, 2010
consultel1
george peters
  • 860 Answers
SOURCE: how to change the time one hour ahead
5.- Press soft key "CHANGE"
7.- Select AM or PM
9.- Press soft key "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press soft key "CHANGE"
13.- Enter year
15.- Press soft key "CHANGE"
16.- Enter month
18.- Press soft key "CHANGE"
19.- Enter day
Posted on Mar 19, 2010
I need to chjange the time on my Nortel T7316E but
The 4 top line/feature keys in the display field are used for programming. The top right arrow is the show key, the bottom right arrow is the next key, the bottom left arrow is the back key and the top left arrow is the heading key.
Mar 15, 2010 | NorStar T7316E Corded Phone
Need to change the time on my Nortel T7316E
Leave the handset in the cradle and press:
Feature (star) (star) T I M E
Follow the prompts to change the time & date.
Mar 13, 2010 | NorStar T7316E Corded Phone
Need Help! I have a nortel T7316E, for some
go to tek-tips.com they have a Nortel Norstar and BCM section in there that will get you the help.
Feb 09, 2010 | NorStar T7316E Phone
Time change
Below is a link to instructions on how to change the time on a Norstar system
Norstar Time change
Mar 11, 2009 | NorStar T7316E Corded Phone
Step 1
Mar 11, 2009 | Lands Phones
TIme Change
Press the function button.
Then enter **8463 (do not forget the stars.)
Then enter password : 22742 or 23646
Feb 23, 2009 | NorStar T7316E Corded Phone
NorStar T7316E Corded Phone - voicemail / ring time
Go to programming of Norstar which will be F**266344 password will be 266344.
Dispaly shows u terminal and extensions.
press show
then next display will show u capabilities.
Press show then next display will show u FWD no answer.press show then next.and change the ringing as per ur requirement.
Norstar T7316e
chang the call log options to none on the specific phone you want it to stop on. or you can go to feature settings and change the call log options to 0 system wide..
Mar 26, 2008 | NorStar T7316E Corded Phone
Fix time
log in thru a telset and when the 4 lights light up on the right hand side of your phone hit the bottom right button till you get to time and date and you change there.
Mar 18, 2008 | NorStar T7316E Corded Phone
NorStar T7316E Telephone Logo
195 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
