Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Security key not valid - Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Posted by jcwood2 on
Carl Navarro
  • 2,460 Answers
If it's a PSK, then it's case sensitive and anywhere from 8-64 characters. If it's WEP, then it's HEX characters (not case sensitive) either 10 or 26 characters.
If you've lost the key, then you'll have to log into the router and read or reset it.
Carl
Posted on Dec 14, 2009
I called myself programming the new keys for my pt cruiser, but,it didnt take. At first it would start and run for a few seconds, now it wont turn over.what did I do wrong and how can I fix this?
Takes the master key to get it started again. The security gives you 3 tries to get the vehicle started, after the third time, it kills the starter.
2002 Chrysler PT Cruiser Note: You must have two valid keys to add a new key to the system.
1. Insert the first valid key into the ignition switch. Turn the ignition switch to the
ON/RUN position for at least three seconds, but no longer than 15 seconds.
Then, Turn the ignition switch to the LOCK position and remove the first key.
2. Insert the second valid key into the ignition switch. Turn the ignition switch to
the ON/RUN position within 15 seconds. After 10 seconds, a chime will sound.
In addition, the Vehicle Security Light will begin to flash. Turn the ignition switch
to the LOCK position and remove the second key.
3. Insert the new key into the ignition switch. Turn the ignition switch to the
ON/RUN position.within 60 seconds. After 10 seconds, a single chime will
sound. In addition, the Vehicle Security Light will stop flashing. To indicate that
programming is complete, the Vehicle Security Light will turn on again for
seconds and then turn off.
The new key is now programmed. The Remote Keyless Entry transmitter will
also be programmed during this procedure.
Repeat this procedure to program up to eight keys.
Oct 09, 2016 | Cars & Trucks
Find my product key for McAfee LifeSAfe
The product key comes with the disk in the retail box, or if it was a download version, it should have been supplied by the vendor. There is no copy of the license key in the PC; it is validated over the Internet and a registry key set for validation by the validation server.
Oct 31, 2015 | Mcafee Internet Security Suite 08 for PC -...
How can i get a manual for 2005 jeep liberty ?
Owners manual.. Dealer with he VIN#. Mechanics manual, any parts store. It covers all the Liberty's.
Oct 27, 2015 | 2005 Jeep Liberty
USB dongle isn't recognized
you didnt set it up on that computer so it wont detect anything
Jul 17, 2015 | Datacard (IDWorks)
I get a message saying windows did not pass my genuine validation and i enterted the key#on the pack of my pc but it wont go through please help
if you used a valid key with a valid copy of the software (and the problem still persists), then you need the WGA plugin. You can download it at microsoft website.
Jul 17, 2011 | Microsoft Security Essentials
I un connected the battery to my dodge charger 06 and then reconnected it now it will not start what could be wrong with it
CUSTOMER LEARN METHOD
The Customer Learn feature is only available on domestic vehicles, or those vehicles which have a U.S. country code designator. This programming method also requires access to at least two valid Sentry Keys. If two valid Sentry Keys are not available, or if the vehicle does not have a U.S. country code designator, the Secured Access Method MUST be used to program new or additional valid keys to the SKREEM/WCM. The Customer Learn programming method procedures are as follows:
  1. Obtain the blank Sentry Key(s) that are to be programmed as valid keys for the vehicle. Cut the blank key(s) to match the ignition switch lock cylinder mechanical key codes.
  2. Insert one of the two valid Sentry Keys into the ignition switch and turn the ignition switch to the On position.
  3. After the ignition switch has been in the On position for longer than three seconds , but no more than fifteen seconds , cycle the ignition switch back to the Off position. Replace the first valid Sentry Key in the ignition switch lock cylinder with the second valid Sentry Key and turn the ignition switch back to the On position. The second valid Sentry Key must be inserted in the lock cylinder within fifteen seconds of removing the first valid key.
  4. About ten seconds after the completion of Step 3, the security indicator in the instrument cluster will start to flash to indicate that the system has entered the Customer Learn programming mode.
  5. Within sixty seconds of entering the Customer Learn programming mode, turn the ignition switch to the Off position, replace the valid Sentry Key with a blank Sentry Key transponder, and turn the ignition switch back to the On position.
  6. About ten seconds after the completion of Step 5, the security indicator will stop flashing, stay on solid for three seconds , then turn off to indicate that the blank Sentry Key has been successfully programmed. The SKREES/ SKIS will immediately exit the Customer Learn programming mode. After the ignition is cycled the vehicle may be started using the newly programmed valid Sentry Key.
NOTE: The Remote Keyless Entry (RKE) Transmitter will also be programmed during this procedure.
Each of these steps must be repeated and completed in their entirety for each additional Sentry Key that is to be programmed. If the above steps are not completed in the given sequence, or within the allotted time, the SKREEM/ WCM will exit the Customer Learn programming mode and the programming will be unsuccessful. The SKREEM/ WCM will also automatically exit the Customer Learn programming mode if it sees a non-blank Sentry Key transponder when it should see a blank, if it has already programmed eight (8) valid Sentry Keys, or if the ignition switch is turned to the Off position for more than about fifty seconds .
NOTE:
  • If an attempt is made to start the vehicle while in the Customer Learn mode (security indicator flashing), the SKREES/SKIS will respond as though the vehicle were being started with an invalid key. In other words, the engine will stall after about two seconds of operation. No faults will be set.
  • Once a Sentry Key has been programmed as a valid key to a vehicle, it cannot be programmed as a valid key for use on any other vehicle.
Jun 09, 2011 | 2006 Dodge Charger
I cant switch on my phone nokia3110c , every time i tried to switch on it says CONTACT SERVICE
hi,
your phone have a software problem and its cause is "security test failed"thats why it has a contact service status...by fixing that you need this gadget ...
1.mx key activated dongle with ufs interface
2.3110c fbus cable (same as 3500c and 6300
3.)modified pm 1 and 309 of 3110c
procedure...
a)open mx key
b.)connect the phone to mx key using fbus cable
c.)in mx key select bb5
d.)bus check and you you will see this logs
SIMLOCK seems to be valid
SUPERDONGLE_KEY seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
in this logs you will noticed that security _test is the only failed...
e,)we will continue by selecting PM then thick PMM authentication
f.)then your pm now is authenticated ,write the modified PM (by writing modified pm ,thick load from file ,then write)
g.)after writing PM here now is your phones logs...
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
h.)now you need to unlocked the phone by clicking ,SERVICE ,IMEI and SECURITY then INIT SIMLOCK...and you phone is done
always remember ,when doing software action to your nokia phone ,always back up the rpl to prevent more damage..thanks for trusting fixya..
Jun 19, 2010 | Nokia Cell Phones
How to program a new remote control for jeep grand cherokee 2002
Programing Sentry keys: 1. Dealer-Programming additional Sentry Keys (requires ONE original key)
In situations where only one key is available, keys must be programmed by the dealer via the Secured Access Method. The Secured Access method applies to all vehicles. This method requires the use of a DRBIIIt scan tool and will also require that you have access to the unique four-digit PIN code that was assigned to the original SKIM. The PIN code must be used to enter the Secured Access Mode in the SKIM. This PIN number may be obtained from the vehicle owner, from the original vehicle invoice, or from the DaimlerChrysler Customer Center. Refer to the appropriate diagnostic information for the proper Secured Access method programming procedures.
2. Self-Programming additional Sentry Keys (requires TWO original keys)
Detailed steps: (1) The first step of course is to acquire a blank transponder key. These can be purchased from your Jeep dealer or bought online. Online prices are usually around $20.00. You can then take the blank key along with one of your original keys to any key maker or locksmith and have it cut to match, just like with any other key.
(2) Insert one of the two valid Sentry Keys into the ignition switch and turn the ignition switch to the On position.
(3) After the ignition switch has been in the On position for longer than three seconds, but no more than fifteen seconds, cycle the ignition switch back to the Off position. Replace the first valid Sentry Key in the ignition switch lock cylinder with the second valid Sentry Key and turn the ignition switch back to the On position. The second valid Sentry Key must be inserted in the lock cylinder within fifteen seconds of removing the first valid key.
(4) About ten seconds after the completion of Step 3, the SKIS indicator in the instrument cluster will start to flash and a single audible chime tone will sound to indicate that the system has entered the Customer Learn programming mode.
(5) Within sixty seconds of entering the Customer Learn programming mode, turn the ignition switch to the Off position, replace the valid Sentry Key with a blank Sentry Key transponder, and turn the ignition switch back to the On position.
(6) About ten seconds after the completion of Step 5, a single audible chime tone will sound and the SKIS indicator will stop flashing, stay on solid for three seconds, then turn off to indicate that the blank Sentry Key has been successfully programmed. The SKIS will immediately exit the Customer Learn programming mode and the vehicle may now be started using the newly programmed valid Sentry Key.
Each of these steps must be repeated and completed in their entirety for each additional Sentry Key that is to be programmed. If the above steps are not completed in the given sequence, or within the allotted time, the SKIS will exit the Customer Learn programming mode and the programming will be unsuccessful. The SKIS will also automatically exit the Customer Learn programming mode if it sees a non-blank Sentry Key transponder when it should see a blank, if it has already programmed eight (8) valid Sentry Keys, or if the ignition switch is turned to the Off position for more than about fifty seconds.
NOTE: If an attempt is made to start the vehicle while in the Customer Learn mode (SKIS indicator flashing), the SKIS will respond as though the vehicle were being started with an invalid key. In other words, the engine will stall after about two seconds of operation
NOTE: Once a Sentry Key has been programmed as a valid key to a vehicle, it cannot be programmed as a valid key for use on any other vehicle.
From WJ's Forum: http://www.wjjeeps.com/sentry.htm
Hope helped (remember rated this help) Good luck.
Nov 02, 2009 | 2002 Jeep Grand Cherokee
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
63 people viewed this question
Top Belkin Computers & Internet Experts
Mike
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
