Question about Canon CFX-L4000 Plain Paper Laser Fax
This fax machine was donated to our school and we need to change the banner message that appears at the top of page when something is faxed.
Posted by mobleyd on
Anonymous
  • 318 Answers
Presss the Function button and then data registration button ,under settings you will find Tel number set your number.The next funcktion is user name, set your user name and press set.
Posted on Dec 14, 2009
When i switchon my machiene an error occured Print Unable 52 please get me out of here regards
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.
    Open the top cover and remove any foreign obstacles from inside the fax machine. If you see jammed paper or another item inside this area, gently pull it out and then close the top cover securely.
  1. If the error continues to appear, the machine may have a mechanical problem.
    If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Step1: Transfer the Fax Journal Report
  1. Press Menu/Set on the Control Panel of the machine.
  2. Press the up or down navigation key until MISCELLANEOUS appears on the LCD. Then press Menu/Set.
  3. Press the up or down navigation key until DATA TRANSFER appears on the LCD. Then press Menu/Set.
  4. Press the up or down navigation key until REPORT TRANS. appears on the LCD. Then press Menu/Set.
  5. The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Fax Start.
Step2: Verify and Transfer faxes in memory
  4. Press the up or down navigation key until FAX TRANSFER appears on the LCD. Then press Menu/Set.
  5. If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3.
    If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Fax Start.
Step3: Reset the machine
After the Fax Journal Report and faxes in memory are transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
If the message continues to appear on the LCD, please contact Brother Customer Service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 19, 2010 | Brother Multi-Function Center MFC-240C...
Says: Unable to Clean Consult owners manual
Dec 16, 2010 | Office Equipment & Supplies
Unable to print 5A
Dec 15, 2010 | Brother HL-4040CN Laser Printer
Can't receive faxes
The problem is that some one has changed the answering method of the fax machine it writes "F/T" because the fax machine is set to FAX/TEL mode. So to make your fax machine to be on fax mode and on the screen to write " FAX " you need to press the button mode which is located under the screen exactly under the message " F/T " after you will press the button " mode " on the screen it will appear the current mode that the fax machine is set to, so you will need to press the " mode " button until on the screen will appear the message " FAX " when the message " FAX " will appear on the screen do not touch any button on the fax machine and after 2 second on the screen will return to the date and time display and again it will display on your fax machine
" FAX " and it will not display " F/T "
Jul 10, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
How do you change the identity info that appears on the top of each page when a fax is sent?
Take help of the manual came with your Fax Machine. I think you have to reinstall the Machine and inthe process the system will ask you about these details you are asking and you can easily change the identity info that appears on the top of each page when a fax is sent.
Apr 27, 2009 | Office Equipment & Supplies
We have a Panasonic Panafax UF-790
It could be a refilled Kyocera KM-F650 cartridge in a Panasonic UG-5510 box.
They look identical, but are configured differently.
You need to try another cartridge as it appears it is not a machine problem.
Dec 30, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Call Sevice 4
reset the unit..press menu#9000*550 Then press start.Call service 3 has something to do with the temperature of the unit check thermostat @ the fuser unit.replace it because the thermostat is not switching to on/off condition although it reaches its peak temperature.
Mar 17, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Canon CFX-L4000 Plain Paper Laser Fax Logo
61 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
