Question about Toys
I have the original Instructions for Operating the 1033(written in 1953) - the second paragraph of the "How To Connect Transformer" reads as follows: The "Multi -Control" transformers listed in this leaflet have four binding posts located on the top of the transformers. Of these, "A-U" and "B-U" combinations furnish variable voltage for the track. The control arm of the transformer simultaneously regulate the voltage output of both the "A-U" and the "B-U" combinations. The transformer nameplate indicates the voltage ranges of these two combinations.The "A-U" combination supplies any voltage from 5 to 16 volts. The B-U combination has voltage from 0 to 11 volts. In selecting the proper range of voltage for your particular outfit, try the lower "B-U" combination first. If the maximum train speed is not satisfactory, then try the "A-U" posts.
To paraphrase the "How to Connect Accessories" section: accessories work best with fixed voltage - these voltages are obtained from the following pairs of output binding posts: "A-B" 5 volts; "B-C" 11 volts and "A-C" 16 volts.
Hope this helps, Mark
Posted on Dec 06, 2011
If possible, can you guys help me also? I have the same transformer but can't get power to go. I am trying the U-b connections and all that's happening is my wires are getting hot. On the track, which port does the left (mine is green) wire go to and which does the right wire (black) go to?
Posted on Nov 29, 2013
Mark, I would be happyto buy a copy of the 1033 manual from yiou. Mine works fine, but the bell won't ring and the whiostle won't blow with that control. Please reply to [email protected] Thanks
Posted on Oct 30, 2012
