SOURCE: Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
SOURCE: i have a nordic track
First of all you need to check the belt, try to adjust it counterclockwise, opposite side about one full turn. if further you have the same problem means you need to change the console electronics it cost approx 100 usd.
Post further comments for more information....
Good Luck!!
Thanks
SOURCE: nordic track exp 1000 treadmill console
Sound like function pad or upper console I don't know if you can purchase the function pad, but you may have to purchase the entire console and that may quite expensive.
SOURCE: BUYER BEWARE!! I purchased
Watch this video: o 1 Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord. o 2 Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place. o 3 Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled. o 1 Unplug the treadmill and remove the safety key. o 2 Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S. o 3 Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models. o 4 Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw. o 5 Reverse the directions to put the hood back on and the treadmill upright in the original position.
http://www.youtube.com/watch?v=E-q-uS4t6so
1. Power
2. Reed Switch
Check too:Optical Sensor. If have it
Eureka! I stumbled onto a solution based on a comment below. Mine had the same symptoms. It started beeping in mid-run. Then after turning it off, it would not start again. The console would light up but all it would do is beep.
What worked for me was to insert the iFit chip into it. That worked! Then, after removing the iFit chip, my NordicTrack treadmill worked normally. I hope this helps somebody.
