a) Headset failure(rare)
b) Verify with settings printing, if it prints the windows logo fine, then is a software problem and it's comming from the software generating the text or the settings to send to printer.
check the driver if the length and the with are correct, print a test page, check if come the windows logo and the test from all label. check if the barcode is biguer that the label, if it is, is not appear.
2 solution is to reset printer to factory defult (press button until flash 4 times and relese the button.
Are you trying to program in ZPL? if you are then you don't need a driver, send the code directly to the port and it will print. I would firstly reset the defaults to make sure there are no corruptions in the settings. Just in case you not sure, press and hold the feed button, the green light will flash 1 then 2 etc on the 4th flash let the button go and it will calibrate and reset to the factory defaults.
Yes, that is true, but you can take the logo and sharpen it up in a picture editing software. Using the magnifying glass to maginfy and fill in all those holes!
1. click on "start" select "run" and type "services.msc" 2. after open services windows select "print spooler" services 3. stop "print spooler" services 4. click on "start" select "run" and type "C:\WINDOWS\system32\spool\printers" 5. after open the printers folder deleted all the pending print jobs 6. restart the "print spooler" services and try to print now.
Sometimes when a picture or a field is partially off the label, this is truncated or not printed, try to move the position of the image. Roberto Martinez
What software are using? If you use or Zebra Designer Label Matrix, uses its own drivers. If you use another driver, verify that the graphics option is "dithering". Roberto Martinez
