I have a maytag pye2300ayw electric dryer that will not run, i thought it might be the thermal fuse, so i changed it and cleaned out the all the lent. dryer started up and seem to work fine. put a load of clothes in and now it is doing the same thing, won't start. i think it may be the thermal fuse again, but what could be the reason it keeps burn the fuses up?
Thermal fused are one time fuses / maytag want's you to correct the problem that causes this . so dryer is safe. hi heat caused it to fail . so either the fan is not going or there is a restriction causing no air flow . try running the dryer off the vent if it works ok then clean the vent ,, hope this helped . pls leav feed back mm
I would say that maytag has a problem with lint collection. That is why so many thermal fuses blow and why so many people just bypass this "saftey" device rendering it more dangerous.
I would advise anyone with this model Maytag dryer to pull the front body panel and clean the lint out and then replace the thermal fuse.
check out this electric no heat tip...
heatman101
