Http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.htm
These are the fault codes for whirpool. The noise problem is what is bothering me.You can pull the bottom front panel, three screws and see if you have a problem with the wiring harness to the motor, also remove the clean out filter on the water pump and clean that out,(large 3 to 4inch diameter white plastic screw almost dead center and to the left of the pump motor). I would also pull remove the backing plate and check where the drum pulley attaches to the shaft, see if it is broken or makes noise as you turn it. You may see water or brown streaks coming from the bottom of the main bearing shaft assembly, This is a major repair. l would recommend you have a technician check this out, you may have a bad main bearing assembly, bad motor, or bad pump (unlikely) but you need a technician for most of these. I have also seen a sock between the inner and outer drum, causing the drum not to spin up to speed. Good Luck, Appliance Specialists
