Question about Simplicity for Children 4 in 1 Ellis Honey Crib
We need instructioms on how to convert it to the toddler rail bed [email protected]
Posted by thomaskearne on
Anonymous
    New Friend:
Need instructions to assemble a Bassett crib Model # 5089-0512
Posted on Dec 14, 2009
I have a vickie crib .I want to convert to toddler bed. If I take the front rail off there is'nt anything to hold the bed up in the front. It unscewss from the side. Help! Bed was purchaced 9/2008 ...
Is this a 4-in1 convertible crib? The Toddler bed will need the bottom railing and a half rail to convert from a crib to a toddler bed. The half rail can also be removed to make the 4th conversion to a toddler bed with out railing. But to convert this specific bed you DO have to add the bottom rail that came with the bed at purchase.
Mar 10, 2011 | Sorelle Vicki
Converting from crib to toddler bed
It is very simple to convert a crib to a toddlers bed. You just need to remove the side railings by folding them under the bed. It would be automatically converted to a bed that a toddler can use please might you rate me or vote for me
Mar 03, 2010 | Baby Gear
How do I convert from a crib to a toddler bed? Do
Mar 03, 2010 | Sorelle Regal 310 Crib
How do you change the graco 5 in 1 convertable lillian crib into a toddler bed?
Mar 03, 2010 | Graco Ultra Deluxe 5-in-1 4605 Crib
I would like to convert my Simplicity crib #8748 from a crib to a toddler bed.
Mar 02, 2010 | Simplicity for Children Ellis 4 in 1 Sleep...
Need instructions on how to convert my aspen simplicity crib into a toddler bed?
i think this is the same crib that i have. I remove the front rail that slides up and down, then i removed the plastic contraptions that allow it to slid up and down on. I then attached the bed frame on the lowest setting, by first fastening the two back ends first. Then I attached the toddler rails to the bottom of the bed frame and then once they where on I attached the bed frame to the crib with the rails and the brackets for the bed frame pressed together. I hope i explained it so that i makes sense.
Mar 14, 2009 | Simplicity for Children Aspen 3 in 1...
No instructions on converting a Ragazzi crib into a toddler bed
This site has instructions for some Ragazzi cribs.
http://www.babyfurnitureplus.net/instructions/index.html
Nov 17, 2008 | Baby Gear
Kindercraft Convertible
If it is like my KinderKraft crib and you want to make it into a day bed, here is how to do it:
Where the bottom of the sliding rail rests at each end, there are small rubber bumpers that stop the rail from going down too far. With the rail in the up position, unscrew the rubber bumpers (remove completely), then drop the rail as usual except it will continue going down. Let it go down until it comes off the guides and you are done! I replaced the rubber bumpers on mine so I don't lose them, though. I actually just did this two night ago! :) Good luck!
P.S.
Your matress needs to be in the lowest postion in order to safely use this crib as a toddler bed!
My email is [email protected]. If I can help you any more with this, feel free to contact me. If your crib is very similar to mine, I can email you a copy of the manual.
Jun 14, 2008 | Kinderkraft Vermont Crib
Need parts for white graco metal crib with arched ends
i need to know how to get another round piece that goes into the conversion rails for the toddler bed.
May 06, 2008 | Graco Ultra Deluxe 5-in-1 4605 Crib
Convert crib to toddler bed
I finally found my instructions!! It's actually really easy to convert to a toddler bed:
Step one: Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
Step two: Lower the mattress to the lowest setting.
Step three: Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
Step four: You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
That's it.. You've now got a toddler bed!
Apr 26, 2008 | JCPenney All-in-One Nursery Crib
Simplicity for Children 4 in 1 Ellis Honey Crib Logo
Top Simplicity for Children Baby Gear Experts
tina gallow
Resolution IT Dubai
Resolution IT Dubai
ray gallant
Are you a Simplicity for Children Baby Gear Expert? Answer questions, earn points and help others
