I can not locate a Remote For PS3 By Gigaware now if its a controller Follow these steps
Connect to PS3
1. Turn on your console and plug the receiver into the first port on the console. The RX indicator on the receiver flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. The controller’s POWER indicator lights and the 4 port indicators flash.
3. The controller connects with the receiver automatically after about 3 seconds. If successful, the RX indicator on the receiver lights.
4. Press the PS button to assign a controller number. The corresponding port indicator lights.
Manual Search
If you are unable to automatically connect, try manual adjustment.
1. Repeat steps 1 and 2 under “Connect to PS3.”
2. Press CONNECT on the receiver. The RX indicator flashes.
6
3. Press and hold SELECT and L3 (left analog stick) on the controller simultaneously for at least 3 seconds. When the RX indicator stays lit, release SELECT and L3.
n Notes:
• Repeat “Connect to PS3“ or “Manual Search“ if the connection fails again.
• If you purchase a new receiver for the controller, but have previously been using it with the supplied receiver, you will have to follow connection steps again.
Reassigning a controller number
1. Press and hold the PS button for one second. The functional screen displays. Select “Controller Settings”, then “Reassign the controller.” Press X to confirm.
2. Use the D-pad to select the number that matches the controller’s port.
3. Press X again to confirm. The corresponding port indicator lights up.
7
Connect to PC
1. Plug the recevier into a PC’s USB port. The receiver’s RX indicator flashes.
2. Slide POWER ON/OFF to ON to turn on the controller. If connection is successful, the RX indicator on the receiver lights and the 4 port indicators on the controller turn off.
Test the controller
1. Open the control panel on your PC, and double-click “Game Controllers.” Then click “Properties“ and the testing screen appears.
2. Press the buttons of the controller. After testing, press OK to exit. You are now ready to play games.
Troubleshooting
If the controller stops working at any time, or will not connect to PS3 or PC, follow “Manual Search“ steps on pages 5-6.
SOURCE: i cant connect my gigaware
If your PlayStation 3 system is 3.5 or higher it won't work. If you have upgraded to version 3.5 or higher it will overwrite third-party firmware that Gigaware controllers use making the Gigaware controller useless. I would return it and then buy a genuine Sony brand controller
