The TV won't turn ON any more using the remote.
I opened the set and, with a cheater cord installed & Power button ON, the P-PB HD4208T111 Power board LED #8003 is lit GREEN. When the Remote is pressed, LED #8001 then LED #8002 light GREEN for 3 seconds then go out & Relays K8001 & K8002 click plus LED #8004 ALARM lights RED. LED #3 remains lit GREEN until the Power button on the TV is pressed OFF, then both relays K8001 and K8002 click again & all LEDs are extinguished. Examination of all capzapitors displays no irregularities however two huge caps are "puffy" on top, rated at 250 VDC 1500 Microfarad as well as two "puffy" topped caps rated 450 VDC at 330 Microfarads. These maybe normal, I don't know. I'm not even going to discuss the 1.5 inch wide vertical black line on the right side of the display...
IMPORTANT: Different TVs may have different ways of performing the reset procedure. Refer to the Owners Manual CHAPTER 5: SETTING UP YOUR TV > RESET FACTORY DEFAULTS OR CHAPTER 6: BASIC FEATURES > RESETTING TO FACTORY DEFAULTS for your specific TV.
Turn off the TV and unplug the TV power cord. Leave unplugged for at least one minute. Plug it in again to complete this reset process.
When the TV has powered on, access the settings through the MENU button, perform the following reset procedure.
Whether your TV has Wi-Fi capabilities will dictate the steps to perform the second reset procedure. This procedure will reset all settings and channels to their factory default values.
Non Wi-Fi TVs
Use one of the following procedures below to reset the TV.
Procedure 1
Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
Highlight the SYSTEM STATUS menu at the top.
Highlight SYSTEM INFORMATION below and press ENTER.
At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
NOTE: If a PIN code has been set, enter your PIN code. Select DONE and press ENTER.
A warning message will appear, select YES and press ENTER. The TV will turn off automatically after a few seconds.
After the TV turns off, unplug the TV power cord and then plug it in again to complete the reset process.
Procedure 2
Press the SETUP button.
Select Installation > Reset TV.
Enter your PIN code (if a PIN code has been set). A confirmatiom screen appears.
Select Yes, and then press the OK button. The TV will turn off automatically.
Wi-Fi TVs (Smart, Cloud)
Procedure 1
Using the arrow keys on the remote (or volume / channel on the TV), select SETTINGS > SETUP > RESET TV and press ENTER.
A confirmation screen appears. Select YES, and press ENTER. To cancel the reset process, select NO and press ENTER. The TV will turn off automatically to complete the reset process.
Procedure 2
Resetting the TV If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE: Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1.Unplug the TV power cord from the power outlet. 2.Unplug any connected devices (DVD, Set-top boxes, etc...) 3.Press and hold the TV power button for five seconds. 4.Plug the TV power cord back into the power outlet and turn on the TV. 5.Open the on-screen menu to confirm that the TV is responding again. 6.Turn off the TV and reconnect the devices. 7.Turn on the TV.
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work • If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then turn on again. If this happens frequently, the voltage in your house may be abnormally high or low. • Unplug TV. Wait five minutes. Plug it in again.
Hello, it does not power at all, means not eaven a power light blinks in the front of the TV, which also means there could be no power getting to the TV through the cheater cord, or a completely busted power supply due to shorted power regulators, lightning damage or surges in the power line. The easiest is to check the outlet, the power strip braker if you are using one, the power cord going to the TV. The rest of things would be inside the TV(power supply and power regs etc....)
NOTE: Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time. 1. Unplug the TV power cord from the power outlet. 2. Unplug any connected devices (DVD, Set-top boxes, etc...) 3. Press and hold the TV power button for five seconds. 4. Plug the TV power cord back into the power outlet and turn on the TV. 5. Open the on-screen menu to confirm that the TV is responding again. 6. Turn off the TV and reconnect the devices. 7. Turn on the TV.
Resetting the TV If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows: NOTE: Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time. 1.Unplug the TV power cord from the power outlet for 4 hours. 2.Unplug any connected devices (DVD, Set-top boxes, etc...) 3.Press and hold the TV power button for five seconds. 4.Plug the TV power cord back into the power outlet and turn on the TV. 5.Open the on-screen menu to confirm that the TV is responding again. 6.Turn off the TV and reconnect the devices. 7.Turn on the TV.
1.Unplug the TV power cord from the power outlet. 2.Unplug any connected devices (DVD, Set-top boxes, etc...) 3.Press and hold the TV power button for five seconds. 4.Plug the TV power cord back into the power outlet and turn on the TV. 5.Open the on-screen menu to confirm that the TV is responding again. 6.Turn off the TV and reconnect the devices. 7.Turn on the TV. Give the brand name and the model number..
