Most likely your water control valve for the ice maker side is not shutting completely. sometimes it's slow enough to freeze the fill tube shut and sometimes the valve is worn out and not seating. Let me see if I can find some parts I did not thaink Samsung Had a RB2 I was thinging. I'll check but you double check too. be back soon RS2155
I checked and yes that model was a model alone so I'm thinking older than most. There are adaptor kits if the refrigerator is a good one and that is what you need but parts for the ice maker are only pictures now. Let me dig around in the Maytag Library *(Samsung is part of Maytag) and see what I find. Sea Breeze
That model is going to need some special attention if that is the model number. It does not show a water control valve and really I would like some photos. Click on photo to make larger and the click the model number above it and they have a few parts. I will place you a view here=> RB2155BB Ice Maker we may find someone to put on there or fabricate parts, You can find me here at Fixya or=> Here or here=> Sea Breeze Appliance Parts and Technical Services if you need answers let me know! Thank You, Sea Breeze
Do You know what year the model was made or purchased? I bet it's a better model that the ones today! Anyway I have hundreds of old manuals I can look through if you need. I will wait to hear from you at the least I am trying, Thanks, Sea breeze
I talked to someone at appliance411.com and he (Dan) said that was an add on ice maker and would need part numbers and possibly need to be rebuilt with other than the original parts. Good Luck, Sea Breeze
You
have two sides to the water control valve. One side is for the water coming from
fountain and the second side is to refill your ice maker after each cycle of
dumping ice into the ice bin. The freezer should be a 5 degrees or below for
the ice maker to function properly. If the ice maker is empty then fill with
tap water up to top edge of the ice maker and allow to freeze. If after the
water freezes and dumps the ice into the ice bin the ice maker does not refill
I would recommend replacing part=> 67006009 Dual Water Control
Valve
or here=> 67006009 Dual Water Control Valve
If the ice maker has old ice inside and does not want to dump itself it will be considered defective and the ice maker core moduel will need be replaced=> W10190972 Ice Maker Assembly
Whirlpool Ice Maker Troubleshooting
I will be here
should you have any questions, Thank You, Sea Breeze
Please Rate this Solution
