Question about Panasonic KX-TGA101S Cordless Handset
How do i retrieve telephone messages when away from home
Posted by yvonturgeon on
Anonymous
    President:
  • 2,761 Answers
A remote code must be entered to operate the system remotely. The factory code setting is "111" and you can set your own personal code by following the directions on page 31 of the phone system operating guide.
To check messages from a remote location, dial your number from any touch tone phone, enter your code after the greeting message begins, then follow the voice prompts.
Need the manual? You can download/print it here:
http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf
Posted on Dec 14, 2009
3helpful
How do I retrieve messages when I am away from home? Model # EXA15580
Remote access away from home first you must enter the PIN code: 1) Enter the Answer Setup menu, and then the Security Code submenu 2) Enter a two-digit PIN code (01-99) using the number keypad (0-9). 3)Press OK
You can operate your answering system from a remote location using any touch-tone telephone. 1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about 10 rings and sounds a series of beeps. 2) During the greeting message (or a series of beeps when the answering system is off), press 0 and enter your PIN code within 2 seconds 3)listen to the instructions from there (to play incoming messages, press zero-two)
Retrieve messages away from home
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest your select it from the list beginning here to download a copy of the manual.
3helpful
Lost manuel uniden DECT2080, how do i retrieve messages when away from home?
You can download the manual from the manufacturer's web site at
http://www.uniden.com/pdf/DECT2080om.pdf
I moved and lost the manual and code to retrieve
Please let us know the complete model number of the phone.
Thanks.
I LOST THE MANUAL FOR THIS PHONE MODEL 1722 AND I NEED TO KNOW HOW TO RETRIEVE MESSAGES WHEN AWAY FROM HOME. THANKS FOR YOUR HELP
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=20295
1helpful
Retrieving message
See if this works for you.
Remote Operation
When you are away from home, you can operate your answering system with any
touch-tone telephone.Use this function to check for recorded messages, to play or
delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press 0 and enter your PIN code.
3) The answering system announces the current time and the number of messages
stored in memory. Then you hear "To play incoming message, press zero two.
For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command
from the following chart:
Command Function
0 then 1 Repeat a Message
0 then 2 Play Incoming Messages
0 then 3 Skip a Message
0 then 4 Delete a Message
0 then 5 Stop Operation
0 then 6 Answering System On
0 then 7 Memo Record/Stop*
0 then 8 Greeting Message Record/Stop*
0 then 9 Answering System Off
1 then 0 Voice Prompts
If you forgot to turn on answering system the directions for that are here:
Turn on the Answering System Remotely
If you have forgotten to turn on your answering system, you can turn it on remotely
from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press 0 and then enter your PIN code. The answering system announces the
number of messages stored in memory. You hear "To play incoming message,
press zero two. For help, press one zero."
4) Press 0 then 6 to turn the answering system On. You hear the outgoing message
and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Retrieving messages from phone when away from home
Normally people would solve that by calling their telephone company provider.
Retrieve messages
To connect with your answering system:
1 Dial your telephone number from a touch tone phone. 2 When the system answers, enter your Remote Access Code. The system announces the number of messages and begins message playback. 3 Listen to your messages
Change remote access code Press [*] [#]. Follow prompts to set new code.
Panasonic KX-TGA101S Cordless Handset Logo
Top Panasonic Lands Phones Experts
Ekse
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
