My LFX25960ST LG refrigerator is not working completely, the bottom drawer (freezer) work but not the top part (the fridge) the ice maker on the door does work. We already unplugged for more than 12 hours but after connecting again, the FF code comes back. LG is excellent to put high prices on their appliances, but not high quality. VERY dissapointed
Your ice maker freezer fan may be iced up. Take the freezer bin out and look at the back of the freezer. If there is ice built up, you have to defrost it.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
there should be a drain at the bottom under drawer. I suspect that it is obstructed. When unit goes into defrost mode ice melts and refrezzes due to obstruction
Hi, Check in the back rear of the freezer and se if you have ice built up. MOST cases the defrost drain gets plugged behind the rear freezer wall under the evaporator. Please let me know if I can assist you further.
I don't think replacing the filter had anything to do with your problem. If the ice maker is working then the freezer is OK since they have the same cooling source. I had the same problem with this model refrigerator six months after I got it (in 2/2007). The cooling in the refrigerator section failed. The refrigerator fan and the air duct as well as the mother board were replaced. A year later the ice-maker fan froze up. It and the housing were replaced with improved models. The mother board was also replaced again due to software changes related to the ice maker. This model is also part of an Energy Star/LG case agreement to modify the circuits and provide a lifetime annual rebate payment. Check it out and register on the LG web site.
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
You Wrote, LFX25960ST LG FRENCH DOOR REFRIGERATOR DATE OF PURCHASE 7-7-07
DELIVERED 7-13-07 ICE MAKER REPLACED ABOUT THIS TIME LAST YEAR AFTER
TWO MONTH WAIT. NOT PLEASED WITH PERFORMANCE OR SERVICE TO DATE.
REQUEST THIS PROBLEM BE COVERED BY WARRANTY.
Below is the service manual And the explanation for your error. Thank You for using our site. Huuum Please remember to leave a solved rating.
Error Detection Category ERROR CODE : IF Abnormality of BLDC FAN Motor for Ice Making
Error Generation Factors It is caused when F/B signal isn’t over 115 seconds during BLDC FAN motor operating
Remark Poor BLDC Motor connection, DRIVE IC, and TR
