Question about Food Mixers
The rotating part of my mixer seems to have fallen out of place. When I push it up, it starts rotating but with a bad sound. What do I do?
Posted by maritzalew on
Howard Lincoln
  • 235 Answers
Hi, MARITZALEW. You don’t indicate your specific KA mixer model, which limits the quality of the solution(s) I can offer, so I’ll start with a general solution. From the symptoms you describe, it appears that either 1) the agitator shaft (what you attach the beater blades to) is dropping out of the planetary, or 2) the whole planetary assembly is dropping from the mixer head.
The bad sound you hear when you attempt to push the assembly back into place is the gears protesting because the mixer is not operating normally. Continued operation in this manner could further harm the internal transmission gears, if not already damaged.
In either case, one of the retaining pins has probably failed and needs to be replaced. This is a job you can perform yourself, but it will be a little messy but very gratifying.
Do you have your mixer’s Parts List manual on hand? . If you're lacking one, you can download it from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number and select a file under the Parts List. (Check to see it this matches your mixer model). Turn to the pages titled: Case, Gearing and Planetary Unit, which provides an exploded view for the disassembly and reassembly of your mixer, along with all the parts.
Locate the Groove Pin on the parts list and then see where it is show on the exploded view. This pin retains the planetary/agitator shaft to the mixer head, and I suspect this is the pin that has failed and needs to be replaced. There is a similar pin which holds the agitator shaft inside the planetary. Getting to either pin will require the disassembly of the whole transmission. This will be messy as you will need to remove all the grease from the gears and center shaft.
Also, while your mixer’s apart you should check for any other unseemly wear and tear on the gears, etc. You may find more things that need replacement than just the groove pin.
Besides needing a replacement pin(s), grease, and possibly a gear or more, you might consider replacing the gasket, too. I recommend using a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should be search for ‘food grade grease’ if you start digging into the transmission. Prices can vary widely between vendors, so do your comparison shopping.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers may or may not be similar to your mixer, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good luck and have fun. I hope this helps. Howard, Burke, VA
Posted on Dec 14, 2009
Dough hook will not come off
I had the same problem too. There should be maybe 1/4" of loose vertical play of the dough hook (or similar attachment) on the agitator shaft. The hook locks in place rotationally on the shaft until it is pushed up. Before you try to turn the dough hook backwards in an attempt to remove it, push it upwards and hold it up, then rotate.
May 22, 2012 | Hobart A200 Stand Mixer
I cannot remove the flat mixing blade, after mixing cake. It has never happened before, just doesn't move up down or sideways! it seems completely locked.
The blade sounds like it's jammed somehow perhaps simply with some food matter.
Ensure the mixer is not plugged in then try removing the bowl, locking the mixer in the down position and pushing up hard on the blade to try and dislodge it. If it comes free and lifts up then try wiggling and rotating it normally off the mount.
Sometimes with use the attachments can become slightly warped requiring more force to lift them before rotating off the mount.
I once used my own Kitchen Aid mixer with the dough hook attachment to make a whole wheat bread dough. When I was done the hook was a bit bent from the hearty dough. There was also some flour in the mount causing it to jam. Removing the hook attachment proved difficult but not imposable.
Good luck.
Apr 18, 2011 | KitchenAid Food Mixers
I have a Sunbeam Heritage Series Mixmaster, 350 Watts, just purchased yesterday. I used it to mix cake batter, cream butter, whip egg whites....the problem is that it doesn't blend the ingredients. The...
There should be a small lever on the base in front of and below the bowl. It will move to 2 positions. It sounds like you have it set for the small bowl but are using the large bowl. Press down on the lever and move it to the other side. If I'm right, that should correct the problem.
Oct 26, 2009 | Sunbeam Heritage 2346 Stand Mixer
Hobart a200 wont turn untill i turn doe hook then will rotate is this a motor problem?
Sound's to me like the start switch in the motor is bad or sticking.Does the motor hum?
Apr 21, 2009 | Hobart A200 Stand Mixer
HOBART 60 QT MIXER MAKES STRANGE SOUND
could be your contactor bad chattering and it will make a hum to for a spit second
Jan 16, 2009 | Hobart N50 Stand Mixer
Mixer part not rotating
Have recently inherited an old Kenwood Major A707A with same problem, contacted local electrical repair man, experienced with Kenwood mixers. He is fitting a new clutch, will cost about £30. I think its worth it. Anyone out there know where I can get Instruction Manual ?
Aug 14, 2008 | Kenwood Food Mixers
Hobart A-200 Motor Direction
No, do not swap hot and N.
First, verify rotation. As the attachment shaft rotates, it should push the engagement pin into the keeper slot. Looking down on top of the mixer, the planetary should rotate clockwise.
If the unit runs backwards, does it start slow? Can you get it to run either way by giving it a push start before turning on the power? If so, your start switch is not working properly. (Which is my guess) Check your capacitor.
There is mechanical and electronic start switches. (Metal arms and a contact or a little gold rectangular metal can.)
Check it out and let me know what you find -- Mike
May 19, 2008 | Hobart A200 Stand Mixer
The switch is broken
Mine did the same thing. I found the ball bearing inside the switch had fallen off. Put it back on and it works like new!
Pull the mixer case apart. Push in on the seam in the front and back and it will pop open after you remove the 1 screw. Pull the switch apart. There is a spring inside the top part of the switch and a small (1/8") ball bearing should be on top of the spring. Chances are, it has fallen off. Find it and stick it back on the spring while holding the top part of the switch upside down. Put the mixer back together.
Dec 26, 2007 | Braun M880 MultiMix Hand Mixer
Food Mixers Logo
121 people viewed this question
Top Food Mixers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
john h
Are you a Food Mixer Expert? Answer questions, earn points and help others
