Posted on Dec 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have connected a clearco hd9000 projector to my laptop. i cannot get the screen to go to full size on the projector and also the laptop screen goes blank. any help would be appreciated thanks
jasbo
Level 3:
  • Master 2,239 Answers
  • Posted on Dec 28, 2009
jasbo
Master
Level 3:
Answers
2239
Questions
Helped
991230
Points
5072
You have to match the resolutions. you may have to drop it on the laptop.
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Feb 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
6967
Points
41
1) The maximum resolution that this projector will recognise is 1024 x 768.
2) Once connected at the correct resolution, you have to toggle the input switch on the top of the projector until it reads "VGA" on the blue screen (or you get a picture).
3) VGA cables do not transmit sound. You have to use the audio inputs on the side of the projector and a different audio source. Alternatively, get a scart to 3 phono lead (R + L and video) and connect to the 3 phono connections on the side. This should give you sound and a good quality picture for watching TV.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1982
Points
Did you connect via VGA? .. I cannot get a VGA connection for an Xbox to work on it, neither can I connect my laptop or desktop computer to it via VGA, after trying all resolutions.
Any thoughts?
Also, I have good picture quality for television, but cannot get any sound?
Anonymous
Level 1:
New Friend:
  • Posted on Jul 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1982
Points
I have managed to get a good picture for both VGA connecion for my lapop and S Video cable for Sky TV. This has solved the picture problem for me BUT although we have a good picture we sill have NO SOUND? Would be good if someone could tell me a solution/suggestion to solve this problem. PLEASE HELP!!!
Anonymous
Level 1:
New Friend:
  • Posted on Mar 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1982
Points
Clearco HD9000 projector works ok when connected to SKY HD box as defaults to 1080i but when connected to my Blueray DVD it defaults to 1080p... As a result there are lines along the left had side of the projection. How do I get into the settings to change this to 1080i ???
Can anyonw help as very annoying!
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Nov 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3590
Points
I have one of these.
I use it to watch the tv and DVDS. Kids use it to connect to the xbox.
Lamp
Hi
I have a Clearco projector
I just stopped working,not even a sound
Laptop screen resolution
when u connect to projector.after connecting change your laptop screen resolution and by setting lowest resolution you will see full screen.
1helpful
Where can I buy a new bulb for my Clearco HD9000 projector
Its a 150 w metal halide bulb. any electrical supply store or online. about 5 pounds cost
Why is it that my Clearco HD9000 projector defaults to 1080i when connected to my SKY HD Satellite box, which is great but when connected to my Pansonic Blueray it defaults to 1080p resulting in lines down...
> 1080I
This is "interlaced" output -- the 1st horizontal line on the screen is painted,
then the 3rd, 5th, 7th, 9th, etc lines are painted, to the bottom of the screen,
then the 2nd, 4th, 6th, 8th, etc. lines are painted.
Your satellite box probably outputs both 720p and 1080i.
> 1080p
This paints the screen in order: 1st line, 2nd, 3rd, 4th, 5th, etc.
which some video-philes indicate produces a "better" picture,
i.e., smoother display of moving objects on the screen.
Your BluRay player probably outputs 1080p, because BluRay has been designed for High Definition displays.
So, check the manufacturer's web-site for the CLEARCO, to see if it supports 1080p mode.
My HD9000 works perfectly on DVD and videotape but I cannot get television when I put the aerial into the projector. Am I supposed to use some other bit of equipment between the aerial and the projector...
Your HD9000 is only a multimedia projector and has no tuner for Television. You will need a TV tuner/Digi Box/Satelite receiver to be able to watch Television.
Hope that explains it for you.
2answers
Image Upside-down
i think you should enter the setting mode and check their for image flip settings or something.
1helpful
Connecting Clearco HD9000 Projector
I'm not familiar with that particular projector, but I believe I can help you get a couple cables to hook them up.
According to some specs I found * the projector has a VGA connection. Next we need to figure out which MacBook Pro you have. Does it have a silver keyboard or a black keyboard? If the keyboard is silver, you need a "DVI to VGA" cable, at least a metre long. You might want a longer one. If your keyboard is black, your MacBook Pro probably has Mini Displayport. That's a bit more exotic, but I'm sure you'll be able to find a "Mini Displayport to VGA" cable.
You can also get adaptors and then use regular cables.
For audio, I believe they're called 3.5 mm stereo plugs. So you'll neet a 3.5 mm stereo plug to 3.5 mm stereo plug cable. Make sure it will be long enough.
Apple sells both kinds of cables. If you want to save money, you might shop around. I don't know UK stores, so I don't know if I can help much there. I buy my cables at www.monoprice.com, an American site.
* http://www.electrobuys.co.uk/special_detail.asp?prod_id=458&grpid=458
Hope this helps.
Good Luck!
Bot
8helpful
3answers
My clearco HD9000 projector works when connected to my PC, but does not work when connected to my laptop. I get a no signal message. Any suggestions?
You must enable external video on the laptop for one. Also, verify that the resolution is within the projector's range. Most likely, you do not have the external video connector enabled. There should be an "F" key with a symbol that looks like a TV screen. Holding down the function key and pressing that "F" key should toggle between the following 3 options:
1) External screen only
2) Laptop screen and External screen
3) Laptop screen only.
Toggle through the above as well and you should get the projector to work.
Dan
1helpful
Ful size image not transfering 4rm laptop 2 screen thru projector
image resolution is not syncing up. reset the settings to factory default, then hook up the laptop and press auto image. if it still doesn't work, you may need to change the resolution on your laptop.
k24674
ADMIN Andrew
ADMIN Andrew
