Acer Aspire 5050-3242 Notebook Logo
Anonymous Posted on Dec 13, 2009
Disc will not open - Acer Aspire 5050-3242 Notebook
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Dec 13, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
2394
Points
23
If you have something inside that you need out fast. Take a paper clip and straighten it out and push it in the small hole. There is a release clip inside that will allow the drawer to open. You have to use a little (key word, a little) force to open it. Don't cram it and don't be light eiether. You will see the drawer try to open up. Now once the drawer is open you have a new dilema. The laptops cd might be failing. I am going to assume nothing has been changed (new drivers) but you might want to take it by the Nerd Herd and see what is wrong. If you are posting this you must be unsure, so pay them $30.00 and be sure and watch them. Not because you can't trust them, but for you to learn. Always learn.
Testimonial: "thank you this work right off the bat"
Anonymous
Level 2:
Sergeant:
  • Expert 232 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
232
Questions
0
Helped
54791
Points
645
There should be a small hole on the side of the drive. Get a pin small enough that will fit in hole. Push it amd the drive should release!
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray Disc® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
How do I get the disc drive of a dvd recorder to open after getting out the disc and resetting the machine?
Go back through the release process you did the first time to remove the stuck disk. it appears that part of the mechanism that moves the drive did not engage again.
2answers
My device cant open the disc tray please advise me on what to do
Electronics Corporation sells inexpensive DVD players. The DVD players, however, often exhibit problems due to their manufacture and way that they work, which must be dealt with during the course of the player's life. Knowing what these problems are beforehand can aid in resolving difficulties when using the DVD player. In some cases, it can help eliminate the problem before it can become catastrophic
The disc door is not properly closed if the Disc player display shows an "Open" error message. Check that there are no gaps in the door and use the remote to open the disc door. If it will not open, unplug the Disc player and gently pull out the disc door and then push it in. Plug the Disc player back into the AC socket.
If the DVD has not been inserted properly into the disc tray, a "No Disc" error message will come up on the display. Eject the disc and lightly flick off dust using the edge of a lintless cloth. Inspect the disc for damage. Insert it carefully again into the disc tray and use the remote to close the disc door.
Because the Disk player is inexpensive, the power supply is not of the highest quality. Having a surge protector to plug into the Disc player will help to keep the power supply from being damaged over the course of its lifetime.
Have a nice day
2answers
1helpful
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Disc drawer will not open with either the button on the set or the remote control. Display shows "open" the changes to "no disc"
10helpful
3answers
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
2answers
Video, DVD player showing no disc
possibly showing no disc as there might not be a disc in machine or the disc it is trying to play does not playback in machine as in it might be wrong format that the machine example it might be a dvd+r but might only playback a dvd-r
2helpful
2answers
How can I finalize an open disc to view content on disc.
Ekse,
I'm having the same problem that Sandyur is having. There is something on the disc because I can view it on the camcorder. I just can't view it on the pc.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
