Gateway 831GM PC Desktop Logo
Posted on Dec 13, 2009
I have a gateway 831gm. it has an Intel (Augsburg) 915G Motherboard and a Pentium 4 630 cpu 800MHz fsb & 2MB L2 cache. i've been looking for a cpu upgrade and saw that the Pentium E5200 Dual Core has the same 800MHz fsb and 2MB L2 cache. both are LGA775 socket. Is it possible to upgrade the cpu with this motherboard?
Anonymous
Level 1:
  • Contributor 23 Answers
  • Posted on Dec 13, 2009
Anonymous
Contributor
Level 1:
Answers
23
Questions
Helped
6364
Points
40
If both motherboards are LGA775 socket, then the next concern is whether or not the case is capable of having the new motherboard installed into it. Disconnect all power cables to all dv drives or cd drives and hard drives. Disconnect all ribbons from drives to the mother board. If you can get to all of the screws that hold the motherboard into the case, you get away without removing drives. Once you've got the motherboard then you can disconnect the power cable from the motherboard. Remove the memory chips, disconnect the sound cable from the old motherboard. install the memory chips onto the new mobo, Connect the power cable to the new mobo, then install the new mobo into the case. Replace the ribbons from the drives to the mobo, replace the power cables to the drives and reinstall the sound cable to the cd or dv drive. You should be done now.
What are the different cpu's that ux915g motherboard will accept? Can it take a pentium D processor?
This would be the Aopen motherboard from the cube...
They take the following CPU's
Processor Number
Processor Frequency
FSB
Ratio
Cache
5 Series
560
3.60GHz
800MHz
18x
1MB L2
550
3.40GHz
800MHz
17x
1MB L2
540
3.20GHz
800MHz
16x
1MB L2
530
3.00GHz
800MHz
15x
1MB L2
520
2.80GHz
800MHz
14x
1MB L2
3 Series
350
3.20GHz
533MHz
24x
256K L2
345
3.06GHz
533MHz
23x
256K L2
340
2.93GHz
533MHz
22x
256K L2
335
2.80GHz
533MHz
21x
256K L2
Note: With CPU changing rapidly, there might be fastest CPU on the market by the you received this installation guide. This table is kindly for your references only.
Intel core tm duo cpu e4500 motherboard
Intel = Processor (CPU ) manufacturer
Intel Core tm = Trademark. The Intel Core is a Trademark from Intel
CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply - Processor for short.
e4500 is an Intel Core2 Duo processor.
Maximum frequency rate ('Speed') is 2.2GigaHertz.
2MegaByte of L2 Cache. (2MB of L2 Cache)
800MegaHertz Front Side Bus. (800MHz FSB)
Tells me Nothing about the actual motherboard. Look on the motherboard for a Model Number. May be in center of motherboard. May be on edge of motherboard. May be in-between one of the expansion slots, on motherboard.
Post back in a Comment.
Also post what the problem is, in your best description.
Computer does not turn on. (Power Supply does not turn on)
Computer seems to turn on, but get No Signal on monitor, or Sleep Mode on monitor, or Power Saver Mode on monitor.
LED lights light up, and fans spin.
Regards,
joecoolvette
1helpful
Cpu up grade
Yes sir.
The eMachines T5082 Desktop PC uses an Intel D102GGC2 motherboard,
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121031
The motherboard chipset is an ATI Radeon Express 200,
http://en.wikipedia.org/wiki/Comparison_of_ATI_Chipsets#Comparison_of_Northbridges_2
Scroll down the chart under the - Model - heading.
ATI Radeon Xpress 200 for Intel.
Processors Supported;
Intel Pentium 4, Intel Core2
If the motherboard chipset will support an Intel Core 2 Duo CPU, it will support an Intel Pentium D.
Plus you can always go to Intel Support, and look, lol!
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-026580.htm
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_D_microprocessors#.22Presler.22_.2865_nm.29
So what are we talkin' about?
A Intel Pentium D, model 925 or model 930?
Up To a maximum frequency rate ('Speed'), of 3.0GigaHertz
L2 cache of 2 x 2MegaByte (2MB)
FOLLOW Anti-Static Procedures.
THOROUGHLY clean the top of the Processor, and bottom of the Heatsink.
Properly apply fresh, new Thermal Paste.
http://www.hardwaresecrets.com/article/274
For additional questions please post in a Comment.
Regards,
joecoolvette
1helpful
Cpus it can handle
Hello here is some info:
http://www.dell.com/downloads/global/products/optix/en/spec_optix_gx520-gx620_en.pdf
You need a pdf reader (adobe) to read the content.
Intel 945G chipset with Intel Pentium 4 processor with 800 MHz front side bus and Hyper-Threading and up to 2MB of L2 cache and Celeron D processor with 533MHz and 256K L2 cache.
Intel Pentium 4 800MHz FSB socket T with HT, XD, EM64T, and 1MB L2 cache (5xx series)
The homepage is here:
http://www.dell.com/support/troubleshooting/us/en/ussoho1/Product/optiplex-gx520
Try also to call the dell support in your country for more qualified answer.
Good luck
1helpful
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
List of compatible x64 cpu's for motherboard Asus P5P800-MX
Leveraging the Intel 865GV chipset to support P4 CPU on 800MHz FSB, Dual-channel DDR 400 memory, Intel Hyper-Threading Technology, and a full-range of advanced features, P5P800-MX really delivers a full-value, high-performance solution for today's most demanding tasks. This motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800MHz FSB, 1 MB L2 cache, Hyper-Threading Technology and core-speeds up to 3.6GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date. Dual-channel DDR technology doubles the bandwidth of your system memory and hence boost the system performance to out perform any memory existing solutions in the market.
Need a new processor
http://www.dell.com/content/products/productdetails.aspx/inspn_e1405?c=us&cs=22&l=en&s=dfh&~section=specs#tabtop
Select Tech Specs:
Intel® CoreTM 2 Duo Processor T5500 (1.66GHz, 2MB L2 Cache, 667MHz FSB) Intel® CoreTM 2 Duo Processor T5600 (1.83GHz, 2MB L2 Cache, 667MHz FSB) Intel® CoreTM 2 Duo Processor T7200 (2GHz, 4MB L2 Cache, 667MHz FSB) Intel® CoreTM 2 Duo Processor T7400 (2.16GHz, 4MB L2 Cache, 667MHz FSB) You can order the processor from Dell sales and then take it to a local computer shop like Fry's. And they can can install it for a good price. I normally would not recommend replacing a laptop processor unless you have done it previously several times.
Processor
make sure your cpu has a 800mhz fsb
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
