Dell (430-3572) Wireless Adapter Logo
Steve Denton Posted on Dec 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Dell 1526 with a wireless 1390 wlan adapter installed. I had to reinstall the windows that came with the computer. Now the WIFI light does not come on and the system does not recognize the wireless adapter. How do I get it to work again?
Anonymous
Level 3:
  • Master 557 Answers
  • Posted on Dec 15, 2009
Anonymous
Master
Level 3:
Answers
557
Questions
Helped
196591
Points
1635
Go to the Dell site and download the drivers. You will have to do it from another computer and download it to a removable device like a usb stick.
Hi, i have a notebook model HP Compaq nc6400 HSTNN-C18C...today i've formatted with windows 7 home premium 64 bit...but now i've got the problem with wifi connection...even tough in the window of network...
HP BLACK LISTS ALL NON HP WIFI CARDS(MODULES)
HP SOLD IT WITH 3 OR MORE WIFI CARDS HP FROM THEM ONLY
so wifi works at home (are you home) and wifi works on TV
other PC and cell phones, with wifi set to data?
if wifi is good then we focus on the relic nc6400 (2007 made)
the home network must have working set DNS selection too.
the 3 listed are
Choice of Broadcom 802.11b/g WLAN, Broadcom 802.11a/b/g WLAN, Intel PRO/Wireless 3945ABG 802.11 a/b/g WLAN
only those work
and only with HP drivers now gone. hp ended suport
googling them gets me endless virus infected driver, as a nice door prize(sarc off)
next time buy DELL and we can find 1000 of wifi card that work .
or cure #2
is remove the old wifi card from its slot.
then get USB wifi dongle. for w7 make sure it has support for old S7
they do work
https://www.amazon.com/Wireless-Adapter-Window-7/s?k=Wireless+Adapter+for+Window+7
just 1 fast search and there go. www.
Connected computer to wireless network but can't connect to internet
Shut down all computers connected to the network, and reset the router. WAIT for the lights on it to return to normal. Start up one of the computer to make sure it has internet access. This will eliminate any issues the router may have.
Make sure you have the passphrase (password) for the network handy (If that matters.) You need to check to see that the computer using the adapter has the correct IP address, and that the adapter settings are getting the IP address automatically.
IF you still cannot connect, uninstall the adapter, reboot the computer using it, then reinstall it and try again. You may also have to go into the network and sharing center, advanced adapter settings, and remove the network, so it can be re-detected by windows.
Dell NetworkDell Wireless 1350 WLAN MiniPC
The Dell Wireless WLAN Card Utility locates, manages and provides information about wireless networks in your area.
The Dell Wireless WLAN Card Utility allows you to create network profiles, connect to an available network, and diagnose connection problems.
Enable the utility through an icon in the notification area of your desktop, or locate it in the programs list depending on which Dell computer you have.
Turn on the Dell laptop and make sure the wireless switch is in the "On" position.
Right-click the utility icon in the notification area of your desktop.
The icon appears as a set of four green, yellow, red or white bars, depending on the signal strength in your area.
Click "Enable Radio."
Right-click the icon and click "Open Utility" to open the Dell Wireless WLAN Card Utility.
Control Panel
Click "Start" and select "Dell Wireless WLAN Card Utility."
Click the box next to "Enable Radio" and click "Apply."
Click "OK."
http://support.dell.com/support/edocs/network/p70008/en/utility.htm
http://support.dell.com/support/edocs/network/p70008/en/wizard.htm
Dell Wireless 1390 WLAN Mini-Card driver
Hi. You can download the driver from Dell website. I strongly recommend that even there will be more recent versions out there, stay with the versions released by Dell, Dell before releasing a driver tests it with the systems to ensure full compatibility and zero-problems with other devices:
Dell Wireless 1390 WLAN mini-card driver
Also for future needs, it's advisable that you go to the following web page:
Dell Drivers & Downloads
And enter the service tag of your Dell computer, so that you could get drivers specific to your system.
hope it helps
Wifi is not working while iam using in windows XP operating system
Hi Sivakumar133,
Some reasons why wifi stops working is due to corrupted driver or defective WLAN card. There are some ways on how to diagnose this problem, just reinstall the driver and configure it again with the wireless access point. You can download the WLAN driver for this particular system by visiting this link. You will notice that on the Networking Wireless LAN section it has 2 types of WLAN card, Broadcom and Intel. Just try to install the Broadcom driver because this is compatible with XP. If you're not sure what is the model of your WLAN just check it under device manager and look for Network adapter. After downloading, install the .exe file then restart the system. You can now configure again the computer to your router.
Hope it helps.
Thank you for using FixYa.
I have limited connectivity. Both my Broadcom 440x 10/100 Integrated Controller and Dell Wireless 1390 WLAN Mini-Card drivers are up to date.
make sure the access point or router is on DHCP then connect the computer, but if its on dynamic IP... them enter an IP in range of what you have on your AP/Router
Wireless light is off.
I am now on the same kind of computer and I used to have this problem- dell said it's a motherboard problem and they replaced it for free. Now it works just fine!
1helpful
Wireless card in E1505 Dell not finding networks in range
The 1390 WLAN Minicard may not be configured to communicate with your wireless router.
Check the wireless router settings, (check the wireless settings on your other computer) and configure the 1390 WLAN with the same settings eg. SSID, WEP/WAP encryption, etc.
Is MAC address filtering enabled on your wireless router, if so add the MAC address of the 1390 WLAN to the MAC address list in the wireless router.
Check the TCP/IP properties of the 1390 WLAN card the Internet protocol should not have a fixed IP address, set it to Obtain an IP address automatically including the DNS.
Use the Ipconfig command to see the IP configuration of the network cards.
Use the Ping command to see if you can communicate with wireless router.
3helpful
Internal wireless card has been disabled. How do you fix this?
Hi car7924,
First, make sure that the wireless switch on the left side of the computer is turned on (this should make the WIFI light go on -- beneath the lower right corner of the screen). If it doesn't work, then try going to Start Menu > Control Panel > Network and Internet Connections > Network Connections.
You should see the Wireless Network Adapter in the window that comes up. If you don't, you need to download the driver for that adapter. The most common adapter in the D820 is the Dell 1390 WLAN MiniCard, and the driver for it can be downloaded at the following web address:
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Dell-Latitude-D530-Wireless-1390-WLAN-MiniCard-Driver-A17.shtml
If, on the other hand, you do see the Wireless Network Adapter, but it says "Disabled" underneath the name, then right-click it and select "Enable." This should make it work.
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dell 1390 wireless inconsistent on start-up
hi
please uninstall the drivers completely, make restart and either install the original drivers that comes with your laptop or download the latest drivers setup from internet and install them.
most the the problems solve by completely uninstalling the drivers and reinstalling the fresh ones.
i hope this will help you. Please give your feedback
bye
yasir
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
