1997 Volkswagen Golf Logo
Posted on Dec 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The rear wiper on my 2000 golf continues to run intermittently after it is turned off
Anonymous
Level 3:
  • Master 571 Answers
  • Posted on Dec 13, 2009
Anonymous
Master
Level 3:
Answers
571
Questions
0
Helped
156050
Points
1187
Turn it off completely. You have two positions for your rear wiper: intermitten and continuous and you have to turn it completely off to have it off. (two clicks)
1helpful
4answers
Our 2012 Ford Escape rear wiper motor and washer fluid stopped working .
Did you check fuse's & relays ?
Rear Window Wiper Operation
The rear wiper motor is controlled by the SJB. The SJB supplies power to the rear wiper motor from the integrated rear wiper relay. The SJB will activate the relay when all of the following conditions are met:
  • Ignition switch is in the ON position
  • Liftgate glass and liftgate are closed
  • Multi-function switch is in the ON or intermittent position
The SJB also supplies voltage to the rear wiper motor from SJB fuse 21 (15A) when the ignition switch is in the ON position. This power feed is used to continue the wipe cycle when the multi-function switch is turned to the OFF position. The SJB receives inputs from the multi-function switch that applies ground to the low speed wipe input or applies ground to the intermittent wipe input. When either of these circuits are grounded, the SJB activates the integrated rear wiper relay and power is supplied to the rear wiper motor to move the rear wiper motor from the park position. An internal switch in the rear wiper motor then moves to the run position which connects the accessory relay power to the rear wiper motor. When the rear wiper motor returns to the park position, the internal switch in the rear wiper motor moves back to the park position. If the multi-function switch is in the ON position, the rear wiper relay is still activated, power is supplied to the rear wiper motor, and the wipe cycle starts again. If the multi-function switch is in the intermittent position, the rear wiper relay does not activate until the predetermined dwell time has elapsed, at which time the SJB activates the rear wiper relay and the wipe cycle starts again. The SJB is the smart junction box .(computer )
Rear Washer System
The SJB supplies power to the rear washer pump from fuse 21 (15A) when the ignition switch is in the ON or ACC position. The rear washer pump receives ground from the multi-function switch when the wash function is turned ON. The multi-function switch also signals the SJB when the rear wash is activated and the SJB then activates the rear wiper.
Ford escape 2006 rear wiper innoperative
Do you know how these wipers Work / what controls them ? Do you know what a smart junction box is ?
  • Multifunction switch is in the ON or INTERMITTENT position
The SJB also supplies voltage to the rear wiper motor from SJB fuse 21 (10A) when the ignition switch is in the ON position. This power feed is used to continue the wipe cycle when the multifunction switch is turned to the OFF position. The SJB receives inputs from the multifunction switch that applies ground to the low speed wipe input or applies ground to the intermittent wipe input. When either of these circuits are grounded, the SJB activates the integrated rear wiper relay and power is supplied to the rear wiper motor to move the rear wiper motor from the PARK position. An internal switch in the rear wiper motor then moves to the RUN position which connects the accessory relay power to the rear wiper motor. When the rear wiper motor returns to the PARK position, the internal switch in the rear wiper motor moves back to the PARK position. If the multifunction switch is in the ON position, the rear wiper relay is still activated, power is supplied to the rear wiper motor, and the wipe cycle starts again. If the multifunction switch is in the INTERMITTENT position, the rear wiper relay does not activate until the predetermined dwell time has elapsed, at which time the SJB activates the rear wiper relay and the wipe cycle starts again.
Do you know what DTC'S - diagnostic trouble codes are ?
Smart Junction Box (SJB) Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1244 Wiper Rear Motor Run Relay Coil Circuit Failure SJB If the rear wiper is inoperative, Go To Pinpoint Test B . If the rear wiper is always ON, Go To Pinpoint Test D . B1245 Wiper Rear Motor Run Relay Coil Circuit Short to Battery SJB Go To Pinpoint Test B . B1614 Wiper Rear Mode Select Switch Circuit Failure SJB Go To Pinpoint Test D .
Did you have it checked for DTC'S ?
Wiper control module location on a 2000 f250
Did you check the wiper relay's in the under hood fuse box ? There are two ,wiper run/park relay & wiper high low relay ! Also ,did you check fuse's ? fuse # 11 - 30amp location cental juction box . The wiper switch is a input to the GEM module . Generic electronic module . The module in most cases isn't the problem ! Learning how to test these electronic systems is , people do not know how to test so they just replace parts . What they should do is take the vehicle to ford certified Technician who has the knowledge and testing equipment to find an fix it .
The generic electronic module (GEM) receives inputs from the following:
  • multifunction switch
  • anti-lock brake control module (vehicle speed signal [VSS])
  • ignition switch
The GEM uses these inputs to control the outputs to the following:
  • windshield wiper high/low relay
  • windshield wiper run/park relay
  • windshield washer relay
  • rear wiper motor relay
  • rear window washer relay
  • GEM Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1240 Wiper Washer Rear Pump Relay Circuit Failure GEM GO to Pinpoint Test K . B1241 Wiper Washer Rear Pump Relay Circuit Short to Battery + GEM GO to Pinpoint Test K . B1342 ECU is Defective GEM CLEAR the DTCs. REPEAT the GEM self-test. If DTC B1342 is retrieved, INSTALL a new GEM. REFER to Section 419-10 . B1431 Wiper Brake/Run Relay Circuit Failure GEM If the windshield wipers are inoperative, GO to Pinpoint Test B .
    If the windshield wipers stay on continuously, GO to Pinpoint Test C . B1432 Wiper Brake/Run Relay Circuit Short to Battery GEM GO to Pinpoint Test B . B1434 Wiper Hi/Low Speed Relay Coil Circuit Failure GEM GO to Pinpoint Test D . B1436 Wiper Hi/Low Speed Relay Coil Circuit Short to Battery GEM GO to Pinpoint Test D . B1438 Wiper Mode Select Switch Circuit Failure GEM If the windshield wipers are inoperative, GO to Pinpoint Test B .
    If both the windshield and rear window wipers are inoperative, GO to Pinpoint Test L . B1441 Wiper Mode Select Switch Circuit Short to Ground GEM GO to Pinpoint Test C . B1446 Wiper Park Sense Circuit Failure GEM If the intermittent windshield wiper speed does not operate correctly, GO to Pinpoint Test E .
    If the speed dependent interval mode does not operate correctly, GO to Pinpoint Test G .
    If both windshield and rear wipers are inoperative, GO to Pinpoint Test L . B1450 Wiper Wash/Delay Switch Circuit Failure GEM If the intermittent windshield wiper speed does not operate correctly, GO to Pinpoint Test E .
    If the wash and wipe function does not operate correctly, GO to Pinpoint Test F .
    If both the windshield and rear wipers are inoperative, GO to Pinpoint Test L . B1453 Wiper Wash/Delay Switch Circuit Short to Ground GEM If the windshield wipers stay on continuously, GO to Pinpoint Test C .
    If the wash and wipe function does not operate correctly, GO to Pinpoint Test F . B1458 Wiper Washer Pump Motor Relay Circuit Failure GEM GO to Pinpoint Test F . B1460 Wiper Washer Pump Motor Relay Coil Circuit Short to Battery GEM GO to Pinpoint Test F . B1473 Wiper Low Speed Circuit Motor Failure GEM If the windshield wipers are inoperative, GO to Pinpoint Test B .
    If the windshield wipers do not operate at high or low speed correctly, GO to Pinpoint Test D .
    If the intermittent windshield wiper speed does not operate correctly, GO to Pinpoint Test E . B1475 Accessory Delay Relay Contact Short to Battery GEM REFER to Section 501-11 . B1476 Wiper High Speed Circuit Motor Failure GEM If the windshield wipers are inoperative, GO to Pinpoint Test B .
    If the intermittent windshield wiper does not operate correctly, GO to Pinpoint Test E . B1611 Rear Wiper Mode Switch Circuit Failure GEM GO to Pinpoint Test H . B1614 Rear Wiper Mode Switch Circuit Short to Ground GEM GO to Pinpoint Test I . B1820 Rear Wiper Motor Up Relay Circuit Short to Battery + GEM GO to Pinpoint Test H . B1839 Rear Wiper Motor Circuit Failure GEM GO to Pinpoint Test H . - All other DTCs. GEM REFER to Section 419-10
Intermittent rear wiper fault. Comes on with the switch off sometimes and then can`t be switched off
this is a question that if your car has the push away rear wiper switch(it goes back to rest position when released)you need a fair amount of patience to be able to switch it off.....you push away again very quickly to turn it ON and OFF.(stupid idea).
Golf 4 rear wiper running on its own
Pull back the wiper stalk which is your wiper lever switch. Pushing it forward would set it to washer mode and wipe a few strokes.
1helpful
Have a 2000 Isuzu rodeo v6. When I go to start
Sounds like the motor has shorted and is receiving an intermittent signal. I would try a pick n pull salvage yard and replace the motor; it should not cost much at all.
Rear windscrenn wiper of Mk4 Golf not working
the linkage that work the wipers are probably gone
Mk 4 golf rear wiper too much water
the jet has a blockage and forcing the water out of the back of the jet clear the jet and put the pipe on properly yates210456
Wipers stay on
There are several possible causes, and maybe a fault code scan would help. You did not say whether the intermittent wipe and various speeds work - do they? In the meantime, check that the wiper stalk is in the correct position.
You could also try removing the front wiper relay to see if that stops them - if so get an auto electrician to try a replacement relay before buying it ;-)
and you could try removing the "rear" wiper fuse - yes rear, if your car has rear wipers. Then please let me know if any of these ideas had an effect! Well take it from there.Thanks, D
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
