Question about Sharper Image Ionic Breeze GP SI730 Air Purifier
Blows fuse when u check continuity between the hot and neutral terminals on the plug, it show a connection. plug it in in and it blows fuse. same issue on 2 units. Low usage, 2002 models.
Posted by anderson_j_w on
  • anderson_j_w Dec 15, 2009
    .5 ohms. house fuse was blown from other source. units ok, me idiot lol
  • Mark Egan May 11, 2010
    Need to know what the resistance of the continuity is. If 0 ohms, then there is a short circuit somewhere. Is the fuse you speak of inside the unit, or is it your house power fuse?
Mark Egan
    President:
  • 1,214 Answers
Cool. How about a rating for me on this one? Thanks!
Posted on Dec 16, 2009
Where does (light green) ground wire attach to, came loose mhen I opened top thank you
We will need to know the make and modek in order to help you.
Apr 25, 2015 | Air Purifiers
Why would new fan motor blow the air backwards
Lmfao at Ken, dude this is a single phase 120 vac motor. You can close your eyes and pick one there is no switching of wires to the motor. YOur hot can go to which ever and your neutral can go to which ever. DOES NOT MATTER :-P don’t reply unless you know blow horn. But just a heads up you can Reverse rotation very easy...
Apr 29, 2014 | Alpine Air XL-15 Air Purifier
My unit will not come on
You probably have a loose connection or component somewhere in the machine, or possibly the motherboard/computer system is non-functioning.
First, check all connections and components!
1) Make sure the plug in the back is inserted firmly and the wall socket is live.
2) The little switch by the plug should have the "I" end depressed and the "0" end up.
3) Check to make sure the back screen is inserted firmly, depressing the interior safety switch. (It will click when positioned correctly).
4) Try both the manual and remote controls. If the manual control work, but the remote ones do not, check to see if the little plastic battery shield is still in the remote. Remove it by pulling on the little tab. If that's not the issue, also try a new battery in the remote.
5) Remove the plug in back, and pull out the fuse to see if it is blown. If so, replace it with the EXACT same size fuse, available at an auto parts store.
If none of these troubleshooting steps works, then it would appear that the problem is in the computerization. Unfortunately, Vollara (new name for EcoQuest) is no longer servicing nor selling the Breeze. Your only option to get it fixed would be to find a dealer who still has some, along with extra parts, in stock. If you call Customer Service, they will give you some trade-up options. 800-989-2299. Use #16618 if you need a referral number.
Jan 25, 2011 | Ecoquest Breeze AT Living Air Purifier
I lost neutral on the electrical service and my cleaner no longer works, i changed the fuse that had blown, but when i turned the filter on it simply blew the new fuse
Blowing a new fuse would indicate that there is some component of the machine which was damaged. The fuse is a safety device which keeps electricity from flowing through defective wiring.
You can visually inspect the machine to see if there are any wires, connections, or components that appear to be damaged, burned, loose, or broken. The plates need to be perfect, without cracks, burned spots, loose mucilage, broken screens, etc. The contact fingers should be screwed firmly in place, and they should press firmly against the screen part of the plate.
If you can detect and then repair any of the above defects, and if the machine still blows the fuse, you can assume that the problem is deeper in the machine and it needs professional help! Unfortunately, Vollara (formerly EcoQuest) no longer makes or repairs the Flair. You can contact Vollara customer service 800-989-2299 to locate a dealer in your area; they may have another machine or know where you could get one. They may also know of someone who could repair it for you.
Jan 12, 2011 | Ecoquest Flair Air Purifier
Absolutely nothing happens when i turn it on, it says to check fuse. how do i figure out where the fuse is
The fuse is contained in a compartment just above, but integral to the plug receptecle on the unit (where the cord plugs into the unit). First unplug the cord from the unit. Next pry the fuse out with a small straight screw driver. If you own the 110v version (as opposed to the 220v unit) you'll need the 1.6 amp slow blow fuse. For the 220v unit use the 1 amp slow blow fuse. Just match up the fuse you remove from the unit. The above information was found in the manufacturerers owner manual. Found online at: http://www.ecoquestintl.com/support/US40135_Fresh_Air_Owners_Manual.pdf
page 7 - Changing the Fuse
Nov 17, 2009 | Ecoquest Flair Air Purifier
Will not turn on Have checked switch under filter Have checked continuity of the fuse plates are making contact Ecoquest Breeze AQ
Have you checked the fuse? It is located in back of the Breeze in the fuse holder next to where the plug connects to the purifier. It uses a 1.0 Amp slow blow for 110 volt models and 0.5 Amp slow blow for 220 volt models.
Oct 28, 2009 | Ecoquest Breeze AT Living Air Purifier
Fuses
Hi lmallu0821,
1. Make sure the safety cut-out switch on the lint screen in the back is properly engaged by the plastic plug on the screen. If this is out-of-position, nothing works (nor should it). This may fix the problem.
2. Check the fuse; if blown again, you have a short someplace that the fuse is protecting you from. Look for loose connections, or damaged components. Also make sure that nothing got left in the machine (eg. thread from cleaning rags), or any wires didn't get properly re-connected when you cleaned it.
If this doesn't fix it, write back with more details - - will the fan run, but not the O3 plates, or vice versa - - I'll need more infomation at that point.
If/when this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Jan 14, 2009 | Ecoquest Flair Air Purifier
Flair motor
Hi vonniekay,
Absent any more details about your situation, this will get you started.
Jon
Oct 04, 2008 | Ecoquest Flair Air Purifier
SI397 Ionic Breeze 3.0
Hi again,
For some reason, I think the system has hanged. My windows shows that you are still typing a message for more than an hour. Our apologies for any inconvenience.
Anyway to your concern, if you were able to take it apart, checking would require that you use a continuity tester set at X 1. You need to check from the plugs back to where it went inside. The idea is to check the wires inside the cord. The meter/needle moving towards the extreme right indicates good continuity. Thereafter follow the two wires where they went inside. It maybe a circuit board, it maybe a fuse, or even the switch. The switch and fuse should also be checked for continuity.
Since your problem is a completely dead unit, then chances are the problem is among those listed above to be checked. If by chance none proved to be defective, am afraid that you have to seek the services of a qualified professional as all other tests requires a fair knowledge of electronics/electrical circuitry and components and possibly parts replacement.
Again our apologies.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 27, 2008 | Sharper Image Ionic Breeze 3.0 Air...
No lights no fan on Alpine Air XL-15
Use a DVM continuity function to see if the fuse is blown, and check all the DO FIRST literature packed with the thing. You probably get to take a note out of the ionizer chamber.
May 13, 2008 | Alpine Air XL-15 Air Purifier
Sharper Image Ionic Breeze GP SI730 Air Purifier Logo
739 people viewed this question
Top Sharper Image Air Purifiers Experts
Marvin
Marvin
James Bradburn
James Bradburn
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
