Question about Epson Stylus C86 InkJet Printer
My epson c86 has stopped working and says it needs a service how do i go about this
Posted by trevor_mcilh on
Martin Smallridge
  • Epson Master
  • 419 Answers
Probably too late to be of much help but in case you're still hoping for an answer this article describes how to fit an external waste ink kit to your C86.
Not too hard and well worth doing as the C86 is still a pretty good printer as I've discovered having resurrected one of my old units.
Posted on Mar 23, 2010
5 Related Answers
Anonymous
  • 556 Answers
SOURCE: epson
Epson says use the built in driver
Follow these steps to set up your Epson product and install the built-in Windows Vista drivers:
  1. Set up your computer.
  2. Connect your Epson product to your computer.
  3. Follow the on-screen instructions that Windows Vista displays to guide you through product driver installation.
Posted on Dec 18, 2007
Anonymous
SOURCE: Epson Stylus C86 won't print
The ssc program doesn't work if your ink light is solid red.
Posted on May 01, 2008
gwbm
Gerry Millward
  • 353 Answers
SOURCE: C86 Epson printer will not print.
Please see your user manual for the meaning of the various light combinations, or if you don't have one, see:
http://files.support.epson.com/htmldocs/sc86__/sc86__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
and look at "Diagnosing Printer Problems".
BOBDOYLE - can you confirm which red light is flashing? If it is the ink light, see the instructions for changing ink cartridges. If it is the paper jam light, check for a paper jam. If you still cannot fix it, come back with a new comment giving any further information.
If this advice was helpful, please rate it.
GUESTS - you both have quite different problems to bobdoyle. If you require specific further help, please register and post a separate request for help.
Posted on Feb 15, 2009
gwbm
Gerry Millward
  • 353 Answers
SOURCE: printer stopped working Epson C86 and red middle light button on
The red middle light is the paper feed indicator. If it is on, it means the paper feed is (or the computer thinks it is) jammed. Remove all paper from the hopper and make sure all bits of paper are removed from the feed mechanism. Press the paper feed button (the middle one) a few times during this process to try to feed through any jammed pieces. If this doesn't work, you have an internal jam or broken feed system, or your main board has gone haywire.
Any further investigation requires you to remove the printer top cover, which you may or may not feel like tackling. If you don't, take your printer to a technician, or sell it on E-Bay for what you can get. If you do, post a new comment to this effect and I will provide a tutorial on removing the top cover. It's not difficult if you know how.
Posted on Apr 11, 2009
Anonymous
  • 113 Answers
SOURCE: flashing red lights, with error message - service required
THESE PRINTERS ARE CONSIDERED BIC LIGHTERS IN A TECH'S WORLD BUT YOU COULD TRY RE-SETTING IT AND OR REMOVING ALL SOFTWARE AND RE-INSTALL FROM SCRATCH.
Posted on May 07, 2009
Where can I find a power chord for Epson Stylus C3810?
Go to your nearest EPSON service center and buy power cord for Epson Stylus C86 InkJet Printer. Have a good day!
Dec 22, 2010 | Epson Stylus C86 InkJet Printer
Paper jam
Your having a hardware issue and you need to have it serviced.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
Mar 27, 2008 | Epson Stylus C86 InkJet Printer
Epson C86 Message says "service
This is a common error with ALL Epson printers and you can find out more about what it means, what you can do about it and even instructions for fitting a waste ink kit for your printer via here:
http://www.octoink.co.uk/waste
In terms of resetting the waste ink counter, the SSC utility should work but you may need the AdjProg (Adjustment Program) instead depending on whether the printer firmware is willing to talk to SSC or not.
Hope that helps.
Martin
Nov 24, 2010 | Epson Office Equipment & Supplies
What cable do i need to connect my netbook to an
The Epson Stylus C86 has both USB and parallel port connectivity. A USB cable would be better.This should be availible in any nearby computer store.The driver is availible in this link:http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=41661&prodoid=46048263&infoType=Downloads&platform=Windows
May 16, 2010 | Epson Stylus C86 InkJet Printer
I need a power cord for Epson Stylus C86. Where can I find one?
Any electrical shop should have them just ask for a figure of 8 power cord
Aug 26, 2009 | Epson Stylus C86 InkJet Printer
My epson stylus c86 is locked flashing paper and ink red lights. The down load from epson to reset the counter for the ink foam,says the printer is no on or have a problem,
TONYCRVTTE and NOVGUNS
Have a look at:
If it's a paper jam, look for and remove paper in feed system. If no paper, is the print head properly parked under the right-hand end of the cover? If not, you may have stuck or detached parking mechanism. Come back to me if this is the case for further help.
If it's "internal error", it usually means the waste ink pads need changing. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C86 Service Manual". You will often find them
for sale very cheaply on E-Bay.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Please rate this advice.
Jan 13, 2009 | Epson Stylus C86 InkJet Printer
Epson stylus C86 printer
If you have already have done 3 consecutive head cleaning and nozzle check from the computer, reseated the ink and replaced the inks, you printer already has a hardware issue. The ink delivery system is clogged and needs to be serviced. If your printer is within the 1-year period I would recommend that you contact Epson Tech support for other options otherwise, you would need to get printer repaired by an Epson certified service center. To locate a servicer in you area click on the link http://www.epson.com/cgi-bin/Store/support/SuppProductSearch.jsp?BV_UseBVCookie=yes
Apr 02, 2008 | Epson Stylus C86 InkJet Printer
Printer not printing
I hate Epson. Had problems with Stylus C82 and now my replacement Stylus C86 has given me nothing but trouble.
I've just replaced all four ink cartridges and now when I print I'm only getting blank pages. I uninstalled, reinstalled, and nothing is working. I even called Epson, twice, only to be routed to the Phillipines where neither person was very helpful, in fact, had a hard time understanding their English. So this is what I;m going to do. I'm taking this bloody Stylus C86 outside and smash it with a hammer..then I'm going to buy a HR Printer...and if anybody from Epson reads this...good luck...your products SUCK!!
Nov 04, 2007 | Epson Stylus C86 InkJet Printer
Epson Service warning
hi, try downloading the ssc utility (just google it). it lets you reset the ink counters, individual ink cleaning etc. once you've opened the main screen you need to right click to get all the other bits. hope this helps
Nov 20, 2006 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Falling star
Kyocera HP Expert
Kyocera HP Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
