Question about Acer TravelMate C110 Tablet PC
I just bought a 2nd hand acer travelmate c110 and does not have anything so i installed a windows xp service pack 2. my question is i cannot use the touch screen is there any driver for it?
Posted by soul_collect on
Anonymous
    Genius:
  • 1,341 Answers
Go on acer's website and look for that particular model where you will get a list of downloads available for this model.You should be able to find the driver for this touchscreen and install it.If this does not work then you may have a hardware fault.
Posted on Dec 13, 2009
2answers
I am looking for travelmate c110 keynoard to replace the current keyboard.
http://www.cdsparts.com/p-37-new-acer-travelmate-c110-series-keyboard-kbt2707001.aspx
This is a place to buy a new one. Let me know if you need any more help. Hope this helps.
Would like to upgrade memory up to 2 Gb, found one slot only . where in the 2nd
There are two memory slots on your computer, one of which is occupied by standard memory. You can upgrade memory by installing a memory module into the available slot.
Installing memory
Follow these steps to install memory:
1Turn off the computer, unplug the AC adapter (if connected) and remove the battery pack. Then turn the computer over to access its base.
2Remove the screw (a) from the memory cover; then lift up and remove the memory cover (b).
50 2 Customizing your computer
3Insert the memory module diagonally into the slot (a), then gently press it down (b) until it clicks into place.
4Replace the memory cover and secure it with the screw.
2answers
Where is internet switch on a acer travelmate c110 tablet pc
On the acer travel mate only some models came with wireless and others did not. If yours has wireless the switch should be located right on the front of the computer. I hope this helps
1helpful
Where is bios in a acer travelmate c110 tablet pc
To access the BIOS Utility, press F2 during the POST (power-on self-test) while the TravelMate logo is being displayed.
1helpful
Why my acer travel mate c110 cannot touch screen ??? is it got a software to install it ? i go acer dun see any software for the Change tablet and pen settings. pls help me ~~~~~~~~~~~~~~~~
Try installing the drivers from the Acer website. The link is
http://support.acer.com/drivers_download.aspx
Select Notebook>TravelMate>TravelMate C110
Under the drivers tab, you will find all the drivers you need for your laptop. Don't forget to select the Operating system or else the drivers will not show up.
How do i turn an acer travelmate c110 on and off
Here is a link to your manual. It's really hard to see the latch from the picture but I would try pressing in the top front button and raising the lit at the same time or sliding the top front slider to the right and raising the lid at the same time. (top front means on the upper lid facing you) good luck. http://www.elhvb.com/mobokive/edwin/laptops/Acer/TMC110SG.PDF
1helpful
I bought lexmark printer (x4650)today but my laptop (acer travelmate c110) does not have a disc tray so can't load the software, is there a way around this, please help i know nothing about computers, I...
Go here to download the driver:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Input your system info, operating system and model number and your good to go.
Please rate this solution, the only compensation I receive is a good rating from you.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Acer travelmate C110 & Acer projector X11602
Hi Andrew,
you can try changing the output of the travelmate, to VGA Or External Device.
ensure you have the correct output lead from computer to projecter. Then on your keyboard you should have a button that changes the output. i.e numerical 5-6-7 or 8. usually says LCD/VGA et,c.
failing this try altering the output in the systems bios setup.
you can enter this by pressing F2 Or esc at bootup.
if your unsure, and none of this helps, i,d suggest visiting acers site. and downloading the user manual(s)
Mike @ Compurepair.
Acer TravelMate C110 Tablet PC Logo
Top Acer Tablets & eReaders Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
NOEL
NOEL
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
