Question about Frigidaire FEF336BC Electric Kitchen Range
Frigidaire CFEF372BC2 electric range - oven door won't unlock after cleaning cycle
Posted by cheschuk on
Anonymous
  • 126 Answers
Hi .The oven door will not unlock until it cools down despite the cycle being finished.If it has not opened in a maximum of 1 or 2 hrs then oven sensor failed during self clean cycle and will have to be replaced.Try restarting self clean to unlock door .If not you will have to do the old coat hanger trick or manually move the lock mech. from rear,sensor cost $30-40.Hop this helps .Please rate my response :)
Posted on Dec 13, 2009
CFEF372BC2 - Oven Door Locked
I would replace it. IF you unplug it and set it to clean it is a hazard if someone opens it. If the safety feature is working it should not self clean with the motor unplugged anyway.
Aug 29, 2014 | Kitchen Ranges
Model number FGEF3032KWB frigidaire oven door won't unlock
Unplug, or turn the household circuit breaker off to the unit for about 15 minutes. If the door does not unlock itself then, contact Frigidaire for a service call. The door latch and/or control board will need to be replaced.
Aug 02, 2012 | Frigidaire FEF336BC Electric Kitchen Range
Problem with the Frigidaire PLES389D Electric Kitchen Range I have a frigidaire PLES389ECC. door will not unlock after cleaning. message reads loc
Oven stays locked during cleaning cycle. then it has a preset cooling cycle which is about 2 hours. This is a long period but normal
Jan 22, 2011 | Frigidaire PLES389D Electric Kitchen Range
How do I unlock the oven door?
If the lock is engaged, is the oven in a self cleaning cycle? If so, cycle power to the oven, that should cancel the self cleaning cycle.
Reply back if that worked or not and I'll try to help you further.
Jan 24, 2009 | Frigidaire FEF352 Electric Kitchen Range
Cannot unlock oven frigidaire electrolux gallery series
Hello, what to do is to start another self clean cycle let the unit clean for about 3 minutes then push the cancel button.This should unlock the door if not a tech will have to come to advance the lock motor . good luck
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
My Electric Frigidaire Convection Oven just locked it's own door! I heard a continual beep..then "Err" "F9" flashed, then beeping stopped and the illuminated "padlock" symbol lit up and the door locked...
I have a similar problem with my electric Frigidaire convection oven, which flashes ERR F9 and beeps after finishing a cleaning cycle; if you haven't had to have it repaired professionally by now you might try cutting the circuit breaker to the oven for a few seconds and then turning it back on. My oven takes a few minutes to reset, after the circuit is turned back on, but then will unlock the door and let me reset the clock and continue cooking as normal. . . until the next time I set the clean cycle.
FW
Seattle WA
Dec 15, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
Frigidaire FEF336BC Electric Kitchen Range Logo
1,414 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
